should i buy? GeIL mem?
Discussion in 'Hardware' started by skin, 26 Jun 2003.
  1. skin
    skin What's a Dremel?
    26 Jun 2003
    i have been offered memory:
    GeIL 512mb 333mhz for 65$ +warrenty
  2. Carbon
    Carbon Banned
    8 Jan 2003
    i dunno but 65$ is only 39.1298 GBP, i wish memory was that sort of price here, i'd buy 3 :D
  3. BenJa
    BenJa What's a Dremel?
    26 Jun 2003
    I'd buy 4... is GeIL memory generally super cheap?
  4. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    It's supposedly the best memory money could buy.
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Well, was - there have been severe problems with the stuff lately...
  6. BenJa
    26 Jun 2003
    Time to look on ebay for GeIL memory then! :)
  7. Kameleon
    29 Apr 2003
  8. Behemoth
    1 Nov 2001
    Ok well, just don't buy that brand of ram then.
  9. mushky
    mushky gimme snails
    24 Mar 2003
    I'd get it new mate. Its not worth the gamble.
  10. skin
    26 Jun 2003
    thanx but since then i got a new comp detail
    amd 2500+ barton xp
    abit nf7(nforce)
    twinmos 256mb 400mhz
    3r systems audi xp
    wd 40gb 7200 rpm 8mb buffer
  11. Kameleon
    29 Apr 2003
    Are you planning to get a matching stick of RAM at a later date for dual-channel? 512MB is the clever thing to do, and dual-channel is nice too ;)
  12. skin
    26 Jun 2003
    abseloutly! (spelling mistake)
    the good thing is that the mobo supports a dual channel and the non dual at the same time (3 slots)
    thanks anywho
  13. Kameleon
    29 Apr 2003
    Do you mean that you're going to run two sticks in dual-channel and another in single-channel? Because that pretty much defeats the point of dual-channel, I think. Stick with one or the other, not a combination of both.
  14. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    how could it do both? its one or the other.
  15. Kameleon
    29 Apr 2003
    nForce2 has 3 DIMM slots, you can have dual-channel running in two and another stick in the other, but it seems a bit silly to me. It's not like you need more than 512MB of RAM anyway, unless you're doing very heavy image processing etc...
  16. Froggy
    10 Jun 2003
    it does sound stupid to have a odd ram layout. and as for more than 512 ram, i love playing Need for speed 6 and Battlefield 1942 at the same time. :D
  17. Pug
    Pug What's a Heatsink?
    16 May 2002
    Actually, the three slot dual channel deal is this - 1 x 512 in one channel, 2 x 256 in the other.
    Bingo, 1GB Dual.
    I went for the Geil and wasn't disappointed for the money.
    It runs at it's rated SPD and it's cheap.
    People with more expensive ram may get a little tighter timings but I'm currently running synced and it ain't my Ram holding me back, 'cause I went a lot higher on my FSB with a lower multi.
    IIrc, the NZ batch was apparently labelled as CAS2, when it would only do 2.5.
    The batch they'd had before would do 2, hence the "Bait & Switch" complaints.
    :idea: Can you check if your motherboard manufacturer lists it as compatible?
  18. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    I'm running 512 of the stuff dual channel now. I haven't tried to OC it, but it is good stock mmory that comes with some nice features like heat spreaders.
    Its so cheap because the company is trying to break into the market.
