Modding Should i paint this
Discussion in 'Modding' started by Cool Hand, 25 Feb 2002.
  1. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
    livedrive
    i started off doing a stealth mod for it (cover made from a drive blank that would flip up), but i use it so much, that it would just be in the way.....
    should i paint it? hate to loose the labeling....
  2. Tim S
    Tim S OG
    8 Nov 2001
    I saw someone not too long ago make a new face for it out of an aluminium face plate.... thats an alternative to painting it...
    I think something should be done to it, its just a question of how you want to implement it ;)
  3. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    Since you are wanting to go silver instead of black, maybe there is something to let the labeling come thru-window film, window decal with brushed aluminum printed on it, some type of dye....?
    There's gotta be something but not sure exactly what. SHould be fun searching and trying tho.
  4. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    i think it would be fine as long as its hidden.
    thats kinda the whole point behind stealthing it.
  5. Haddy
    Haddy World Domination
    22 Jan 2002
    get some of that lettering that they use on motherboards and stuff......i found some at radioshack then just mod a face plate to go over it and lable it on the face plate
  6. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    I wish I could silk-screen stuff myself :eek:)
    Coolhand are you absolutley sure they dont sell a black livedrive?
    Creative I thought was usually good about that kind of stuff
  7. brianpodskalny
    3 Nov 2001
    they do sell a black livedrive, but it still wont match.
    the drive above it looks pretty nice, the paint matches very well. i suppose if you can find the lettering you could always put it back on. but do you really need the labels anyway? if you know what youre doing you can just forgo any lettering and do it from memory.
  8. tk421
    tk421 Idiot.
    15 Jan 2002
    id be forever plugging my bass into the headfone jack and my headfones into the 1/4" input ....
  9. Dr_kazza
    Dr_kazza What's a Dremel?
    2 Nov 2001
    paint it silver... (see siggy for my drive :) ) just keep the manual handy in case you want to look at the labels again... I promise when you start using it you will know which ones are the normal inputs/outputs without labels!
  10. Cool Hand
    21 Nov 2001
    nice...looks like im painting it.....
  11. FL@MeS
    FL@MeS What's a Dremel?
    4 Jan 2002
    make a face plate if you dont wanna lose logos, etc... and just leave it up - or off -- if its not annoying you leave it open most of the time.... we'll be impressed with pics with the lid down.... ;)
  12. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    ever since macro black, all I can think of is clear lexan painted from behind... if you were going to make a custom face for it. I like the painted one above though... wow, I didn't help at all :D
  13. eddie_dane
    31 Jan 2002
    Cool Hand, does that glass door get in the way alot? I really dig that case and considered it for a while but I have little danes running around my house and they like to do "mods" of their own and that door would last about 5 seconds in my house... just curious
  14. Cool Hand
    21 Nov 2001
    i think your looking for Dr_kazza to answer that one, but from what i understand, the door is cool....i thought it got in the way of the livedrive buttons, but that doesent appear to be the case....i have a lian-li pc 68, and im thinking of making a door for it out of plexiglass..
  15. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    I just had an idea :D
    I wonder if you could vaccuum form a piece of black plastic over the top that way you can go back when ever you like ? :D
  16. tk421
    tk421 Idiot.
    15 Jan 2002
    oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo™
  17. Cool Hand
    21 Nov 2001
    an excilent idea...dont think i have access to anything to do it though...
  18. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    CoolHand - If you are painting, Plastikote is the way to go. My drives are painted with aluminum coloured fast dry enamel, code B30. It's *almost* an exact match, and far better (IMHO) than just painting it silver.
    See piccies in the VFD thread for results.
  19. Cool Hand
    21 Nov 2001
    cool stuff...i use krylon bright silver metallic myself.....works great (the webcam pic dont show it to well...but looks awesome irl)
  20. Dr_kazza
    2 Nov 2001
    I was worried that the door would get in the way but to be honest it doesn't at all... and isn't any bother.
    I think I would have preferred the non frosted version but there you go.
    Tell you what is funny... Stegga1000000 from Ocuk boards seems to develop tourettes whenever someone mentions the 210.
    Worth buying just to bait him ;)
    I am gutted that I bought the CM210 though, like everyone else I want a macroblack :/ mind you I'm very happy with 2nd best :)
    Kazza
