Build Advice should i upgrade or na?
Discussion in 'Hardware' started by grritsshawn, 19 Apr 2011.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Well i do a lot of 3d models and watch a lot of movies and edit them and also i game a lot but i want to be able to max everygame out also and have it very future proof
  2. Tangster
    23 May 2009
    3D modelling and video editing with games?
    i7 2600k (for rendering, i5 2500k suitable if you don't render that often and aren't going to use all the available speed)
    GTX570/580(should help in the modelling viewport if your models are really complex)
    SSD
  3. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    QFT.
  4. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    I'd go for more power anyway to be honest extra cpu is very handy when running multiple apps (photoshop when texturing etc).
    How much 3D work do you do? and how complex is it? do you ever do physics calculations or multi pass mental ray renders or anything?
    Unless you're doing very complex stuff your i5 is fine for a while, whereas an SSD makes every part of your system faster, including the boot time of 3D Max or any other apps you decide to put on there.
  5. Tangster
    23 May 2009
    Looking at his avatar, sketchup models?
  6. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    +1 on SSD.
    While it might not make huge differences on gaming side, for work it will make the experience much better with everything becoming much more snappier, especially if you open and close files and apps a lot.
  7. grritsshawn
    20 Apr 2009
    sketch up models i do a lot of sometimes just for fun not really caring for the scales others down to the mm. I do runescape, cod, and dirt 2 videos and some NFS, use sony vegas and camstasias for that stuff and as for photoshop a very little unless my friend james is helping me do a design for a case he will do coloring and shadowing
