PSU Should I wait for my PSU to die or replace it now?
Discussion in 'Hardware' started by oscy, 30 Jan 2019.
  1. oscy
    oscy Modder
    22 Sep 2011
    The fan whirs a bit noisier than it used to, it's especially crackly once in a blue moon when first starting up on a cold morning.
    It's a 750W Seasonic EVO 80. When I got it 4 years ago, it was a 2nd tier PSU.
    I had a random PSU in a pre-build die years ago, but it didn't damage anything.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I take it that the crackle comes from the fan itself?
    If that's the case just give it a good clean with some compressed air. See how it behaves after.
  3. oscy
    oscy Modder
    22 Sep 2011
    All been cleaned already. Well I had a fan cover so that needed cleaning, spraying in the PSU didn't seem to shift anything if there was anything left in there.
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Personally, having had a top tier PSU go pop and take out a motherboard with it, I wouldn't chance it. Mine was 6 or 7 years old when it popped smoke but there were no signs of impending doom for me to react to.
    If you're getting the warning signs, take action.
  5. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Playing chicken with your PSU in your PC is like chancing your brakes on your car...
  6. Vault-Tec
    30 Aug 2015
    I agree it lowers the risk. But, we all know of the law of sod where the chances of a brand new one going pop are equally as high.
    I would personally check the caps, read the voltages and feel relatively safe.
  7. Sentinel-R1
    13 Oct 2010
    You would advocate opening up a PSU to check the caps and therefore void any remaining warranty???
    That unit has a 5 year warranty so there's still a year left. I can't agree with you on this one matey and in this instance, I'd say that's poor advice.
  8. Vault-Tec
    30 Aug 2015
    If it's under warranty leave it alone. I thought he said it was 7 years old, must have been mistaken.
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    OP says in the first post that the PSU is 4 years old, but Sentinel mentioned that his PSU went bang when it was 6 or 7 years old :)
  10. Vault-Tec
    30 Aug 2015
    Too much going on in my brain haha.
  11. oscy
    oscy Modder
    22 Sep 2011
    I bet if I posted it (which I have to pay for) to do the warranty thing, they'd just say it's fine. It's only like a decibel or 2 louder.
    I found out the noisiness of starting up on a cold day was from my CPU fan anyway (the good old Hyper Evo 212).
  12. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    IMO, it depends how you run your other hardware.
    On the bleeding edge all the time? Maybe swap it at the end of its warranty and either sell it on here or shelve it for future projects.
    More than a few generations behind at any one time? Eh, bollocks to it. Replacing older stuff isn't so expensive.
  13. oscy
    oscy Modder
    22 Sep 2011
    Still rocking the 2500K and GTX 780 I bought from here 4 years ago. :naughty:
    liratheal likes this.
  14. MrRobot
    MrRobot What's a Dremel?
    31 Jul 2017
    Replace it, maybe cash in something for it while you still can
  15. liratheal
    20 Nov 2005
    Same. I was running my i7/X58 until June/July last year when it finally got replaced. With more mid-range kit! Graphics card gets swapped slightly more often, being a 480 4gb , but even that's not bleeding edge of anything.
  16. Vault-Tec
    30 Aug 2015
    Just playing devil's advocate.. How many threads do we see on here with people saying "My old PSU died and killed my hardware. I should have replaced it as it was very old". I don't count many.
    As I said before I would trust a PSU I have had for four years that has not let me down over a new one that could die within a few weeks. I had a DOA brand new PSU that I had to RMA. All it did was click.
  17. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Spanner in the works...
    Built a PC for a mate of mine, brand new Corsair RM850x died within ten minutes of powering the machine on...without any substantial load.
    As VT says, just because something is new doesn't mean it's any better than something older and trustworthy.
    If the PSU in question was mediocre when it was new then yeah I can understand replacing it, if it was a decent PSU when it was new then there would be no need in my mind.
  18. Gareth Halfacree
    4 Dec 2007
    Bathtub curve, innit. Failures will cluster around the very start of expected lifespan (faulty component, manufacturing defect, design flaw) and the very end (wear and tear.) Doesn't mean one can't die in the middle of the curve, just means it's less likely than at either end.
    modd1uk likes this.
  19. Wakka
    23 Feb 2017
    That's because they are too busy crying over their lost hardware to make forum threads!
  20. Vault-Tec
    30 Aug 2015
    Nah. We know which PSUs are dodgy very quickly because they get a bad name for themselves. So example, Corsair AXi are rubbish but AX are awesome. Also, what is the point in spending tons on a PSU *for* build quality and reliability if we're just going to chuck them in the bin when we get paranoid a year before the warranty goes?
    I have confidence in quality. That is why I bought a Enermax Platimax 1550w for my latest build second hand for £70. My AX1200? lol that is about 7 years old and still works perfectly (I had it all apart last year, complete clean and cap check and everything was perfect in there).
