PSU Should I wait for my PSU to die or replace it now?
Discussion in 'Hardware' started by oscy, 30 Jan 2019.
  1. oscy
    oscy Modder
    22 Sep 2011
    According to the tier lists, Corsair AXi and AX are tier 1 and the best Corsair PSUs. :worried:
  2. Vault-Tec
    30 Aug 2015
    I know, but they were not made by the same OEM IIRC, and certain models of the AXi were known to go pop long before they were old.
  3. oscy
    oscy Modder
    22 Sep 2011
    The tier list LIES?
  4. Vault-Tec
    30 Aug 2015
    No. The AXi was the replacement top tier PSU from Corsair. Sadly they were nowhere near as reliable as the AX series.
  5. oscy
    oscy Modder
    22 Sep 2011
    So the AXi is super reliable, just a little less than the AX if you're anal about it?
  6. Vault-Tec
    30 Aug 2015
    Not from what I have seen, no. I have seen quite high failure rates. IIRC (and don't quote me here as I am going from memory) the AX range were built by Seasonic and the AXi by another OEM. So they were completely different and not comparable to each other.
  7. oscy
    oscy Modder
    22 Sep 2011
    How come they're on high tiers?
  8. Vault-Tec
    30 Aug 2015
    Because I guess Corsair didn't know they were unreliable?
    They're good quality units but failure rates were very high.
    So to quote Half Life? Unforseen Circumstances.
  9. oscy
    oscy Modder
    22 Sep 2011
    It seemed tier lists were subjective-kinda-factual lists by us, the customers, and testers based on reliability and how bad things went when it failed (explosions, flames, taking everything with it).
  10. Vault-Tec
    30 Aug 2015
    AXi were very very expensive. So they were top tier. As I say though they just weren't reliable . It does happen from time to time with PC gear.
  11. oscy
    oscy Modder
    22 Sep 2011
    Tier lists are based on price?
  12. Vault-Tec
    30 Aug 2015
    And supposed quality, yes. I won't accuse Corsair of cutting corners by switching from Seasonic to some one else, but I guess they just got let down a bit. I *think* they actually make their own units now? no idea. It's usually fair to say that Seasonics are pretty bullet proof.
  13. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Most AXi units are Delta OEM as I remember. Given my choice, I'd take Delta over Seasonic-but remember my background in OEM and multi socket systems. I need a new one.
