Cooling Shrouds are awesome, even if they are ghetto-fabulous
Discussion in 'Hardware' started by Morphine, 30 Oct 2003.
  1. Morphine
    Morphine weeee!
    23 Feb 2002
    wow....
    I had my BIX mounted in my case with two 120mm papst fans mounted directed to it. The temps were OK, bu I wasnt all that happy with them. So The other night I completely rebuilt my system. I was even able to trim about 6 inches of tubing by just reworking my routing.
    But anyways, on with the main part of this thread. I took some of my erector set pieces (I loved erector,lego and kenex when i was younger) and used them to rais the pushing fan about an inch from the rad. I then wraped this framework in duct tape to create an airtight seal. My temps have gone down by 7*C!
  2. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    I should do the same on my BIX2 ... maybe that would bring down my already awesome temps ... hehe. When my G5 Alu case is finished I`ll do that I suppose.
    Cheers
    Fred
  3. Risky
    Risky Modder
    10 Sep 2001
    Its a shame no-one is selling them yet. I have a WTD add out for a dead 120mm fan to do the job for me.
  4. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i made mine out of cardboard and packing tape :D
  5. Conrad
    Conrad What's a Dremel?
    23 Jul 2003
    I picked up a cheap 120mm fan last week in the forums, i've already chopped the fan out and gave it a bit spit and polish ;) and plan on using the housing/frame as a shroud when mounting the fan on to my bix. i'll post some pics once i get it all attached.
  6. Supercool
    Supercool Gone.
    31 May 2003
    I've got 2 dead titan alu frame fans that kustom pc's sent me (free :thumb: ), I just need to get another 1 from somewhere, then I'm gonna use them as shrouds :D
  7. Pug
    Pug What's a Heatsink?
    16 May 2002
  8. Risky
    Risky Modder
    10 Sep 2001
  9. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Hey thats not a bad idea!
  10. Fubar
    Fubar What's a Dremel?
    7 Oct 2003
    i got my 120mm fans from xoxide 2.99 (USD) a pop they are still selling them..... and they are green uv reactive to boot :)
