Small Form Factor shuttle motherboards
Discussion in 'Hardware' started by notatoad, 28 Oct 2004.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    can you buy a shuttle motherboard without the case or do you have to buy the whole barebones system? or is there any other good flex-atx motherboards i can buy for socket 754?
  2. Go4t
    Go4t i
    13 Dec 2003
    yes you can but last time i checked you couldnt get the s754 mobos, but that was a couple months ago
  3. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    yes you can but its not worth the price, the barebones option is only slightly more expensive and you get the psu/case etc.
    The newer boards tend to take a while to come out after the main barebones though.
    www.gemma.co.uk in the uk or shuttle direct in the usa.
  4. shroom
    shroom What's a Dremel?
    6 Aug 2003
    You can purchase all shuttle mobos from shuttle.com.
