Small Form Factor Shuttle PSUs
Discussion in 'Hardware' started by SJH, 5 May 2004.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    I'm considering purchasing this:
    http://www.tekheads.co.uk/s/product?product=602759
    However I would like to know the dimensions of it...does anyone have one they could measure for me? :D
    Thanks a lot!
    Edit: Also...just to be sure, are they compatible with the ATX standard?
    -Sam
  2. SJH
    SJH Minimodder
    24 Dec 2003
    OK I've found the dimensions...190x82x43mm.
    My other question remains though...will this work in a non-Shuttle system?
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Yes it will work in a non shuttle system (it still uses atx standard connectors) so long as your not trying to run too much off it.
    SJH likes this.
  4. SJH
    SJH Minimodder
    24 Dec 2003
    It's going to be for a Mini ITX system so 250w is plenty. All I'll have is the mobo, a hard drive, a VFD and a DVD drive.
    Thanks for your help!
    -Sam
  5. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    You could go for the standard 200W model - thats only £20 and still has the standard ATX connector and is even smaller than the 240W silent-x
  6. SJH
    SJH Minimodder
    24 Dec 2003
    Wow, I didn't know you could get these!!
    Any idea where to get them from? The only places I've seen them only do the 250W model.
  7. SJH
    SJH Minimodder
    24 Dec 2003
  8. Penrhos
    23 Oct 2001
  9. khendar
    khendar What's a Dremel?
    25 May 2004
    Wow...good thing I googled before posting this same question :D
    I'm considering using a shuttle psu in my cube.
