Modding Side panel covering / mesh ?
Discussion in 'Modding' started by MarkW7, 22 May 2011.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I used to have a fan on my side panel but this case now houses a file server and it isn't needed.
    I was looking for some mesh / a covering just to tidy it up a bit and help stop the dust, any ideas where I can pick something up cheapish?
    :thumb:
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Offcut of acrylic from your local signwriter's?
    Chicken wire?
    mvagusta likes this.
  3. danitgeek
    danitgeek Designer
    17 Sep 2010
    Mnpctech for mesh cheap not so sure
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    get a rectangular mesh wastebasket from your local home/office store. you can usually find ones that have a side big enough for a few monetary units.
  5. j0rd
    j0rd FLOSS folder
    13 May 2011
    quick gutter fix, just screw a mesh fan grill into the wholes for the fan mount
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    That'd have to be one hella big fan grill
  8. bulldogjeff
    2 Mar 2010
    How big is the hole. You could probably pick up a15 inch sub woofer grill for about a tenner.
  9. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    360mm, about 12 inches.
  10. DeadP1xels
    30 Nov 2009
    Live near a staples???
    These babys give you a clean piece of mesh for as little as £3 better when you consider B&Q want £15 for something that could barely cover that hole
    Get some sheet cutters and chop it like paper or a dremel if its corrigated whack it between two bits of wood and close it in some vices to flatten it out (althought corrigated would work fine might look better)
    MarkW7 likes this.
  11. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I do!
    I shall keep an eye out for these. Thanks for the heads up! Awesome.
  12. bulldogjeff
    2 Mar 2010
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Maybe my rules lies, google is now telling me.
    360 millimetres = 14.1732283 inches
    I'm assuming there's 15inch ones as well. :p
  14. bulldogjeff
    2 Mar 2010
  15. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Thank you sir, rep for both you and dead pixels. :thumb:
  16. bulldogjeff
    2 Mar 2010
    Glad to be of service and now my work here is done, it's time to rescue another damsel in distress:eyebrow:
