Windows Sidewinder Force Feedpack Pro & Counter-Strike
Discussion in 'Gaming' started by IornRayn, 7 Jun 2002.
  1. IornRayn
    IornRayn Guest
    Alright, I have this force feedback pro Sidewinder, but Counter-Strike will not recognise it as a joystick, anyone know how to make that happen?
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    why do you want to use a joystick with CS. Is it even designed to go with a joystick?
  3. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    yes, you can use a joystick with half life and therefore counterstrike.
    Check the advanced controls section of the configuration menu.
    There is an option there to enable the joystick :)
  4. IornRayn
    IornRayn Guest
    I have tried that.
  5. djgizmo
    djgizmo 1337 pimp
    26 Mar 2002
    are you crayzay??? how are you s'posed to compete with the rest of us if you're using a joystick??? i have a joystick, i just wouldn't dare to try it in any normal 3d shooter...
  6. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    You could use the programing software that you get with the joystick, I cant remeber if you can bind joystick movements to keys.
    If you can just bind up on the joystick to the W key and so one.
    Hope this helps! :)
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    that would take a very long time to do.
  8. Stew
    6 Mar 2002
    Ive played half-life with two joysticks before, it was alot of fun.
    more effective to use a mouse though... yadayadayada :p
  9. RTT
    RTT #parp
    12 Mar 2001
    WASD 0wns you
  10. Fly
    Fly inter arma silent leges
    31 Aug 2001
    WASD???
  11. RTT
    RTT #parp
    12 Mar 2001
    only n00bs use the arrow keys! :eeek: :hehe:
  12. Kevo
    9 Sep 2001
    I even more l337 I use EDSF :D
  13. RTT
    RTT #parp
    12 Mar 2001
    i've seen people turning their keyboards sideways and using REFD!
    odd!
  14. djgizmo
    djgizmo 1337 pimp
    26 Mar 2002
    you can say that again!
  15. Fly
    31 Aug 2001
    I know what you mean now... I was being terminally thick.
    I am well aware of the WASD setup...half of my messages in CS consist of "dasdwsdsdawwdassdsdaadad" followed by me screaming "bloody machine...work damnit!!!" then realising I had pressed Y by mistake...:cries:
  16. djgizmo
    djgizmo 1337 pimp
    26 Mar 2002
    i hear ya... the only thing that fixes this, is to move or get rid of the chat key, and just use voice communication... and that way, you'll play better as a team too...
