Equipment Sigma 150 Macro
Discussion in 'Photography, Art & Design' started by eeevan, 9 Oct 2008.
  1. eeevan
    eeevan Dremel Master
    21 Oct 2007
    I know a few of you are packing one.
    C&C?
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I've owned one for almost two years and I love it.
    IQ is spot on, you couldn't ask for better colour and sharpness for the price.
    Build quality is superb. Bindi dropped mine from chest height and it just cracked the filter ring, no internal damage.
    Focus is a tad slow but you can solve that by limiting the search to the range you are shooting. The full time manual focus ring is very smooth.
    It's quite heavy but that's to be expected of a 150mm lens with macro capability.
    I can't compare to the Canon 100mm Macro but from what I've seen you can easily achieve the same results. Albeit slightly easier when taking insect shots as you can be further from the subject. Conversely you need to be quite still or have a lot of light to get a sharp photo when shooting 1:1.
  3. Darkened
    Darkened Minimodder
    28 Feb 2004
    I'm also interested in hearing comments about this lens. It just may be the next thing on my shopping list.
    Darkened
  4. Vers
    Vers ...
    23 Oct 2007
    The Sigma 150 is one of my favorite lenses I've ever used let a lone owned. BQ and IQ are top notch and on par with Canon's 'L' grade. The focus speed, while not ultra quick, is quite fast for a macro lens which enables it to become a good standard tele. Focal length is also a huge plus as is the additional tripod collar and hood. All in all I'd recommend this macro over most other 1:1's, depending on what is being shot of course. If your into shooting insects and other skittish subjects this is one of the best macro's out there to do it with...aside from the Sigma and Canon 180mm's which come with a higher price tag.
  5. ssR
    ssR Carbon God
    11 Aug 2006
    if it wasn't for the bargain price i got on my 100mm i would probably get myself this baby...
  6. Firehed
    15 Feb 2004
    Is the Sigma 150 what you use for most of your insect shots, Matt?
  7. Vers
    Vers ...
    23 Oct 2007
    Yep, The only other lens I use for insects is the 100-400--mostly for butterflies.
