Silence is here....!
Discussion in 'Hardware' started by Highland3r, 25 Feb 2004.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    After 2 weeks of waiting, finally the SilenX fans arrived on me doorstep (well the site office anyways) after a mate mentioned them to me i had to give them a try, so 2 weeks and 65 quid later here we are.
    The company was really helpful, no VAT or import duty (as far as we are aware so far) was required... all in all a nice experience.
    Now, onto the fans...
    from their list of silent fans, I chose the highest airflow they had, this still however is only 14dB.
    2* thermally controlled 80mm, 28cfm @ 14.4dB
    1* 92mm 36cfm @ 14dB
    and 2* 120mm @ 58cfm.
    With each fan you get a 4/3pin convertor and some rubber mounting "screws" for want of a better word, along with the standard fan fixing kit.
    The fans have a good weighty feel to them, with all the cables either moulded together or braided to ease routing and neatness, with the thermal sensors have a small shink wrap tubing over the end....
    I was a tad sceptical (*sp) at these ratings initially, but after getting the fans powered up, they all seem about right, all of the fans, outside a case are inaudible unless your ear is right up to them.
    Currently i can only install the 80mm's into my case, due to having no 120mm mounts and not being able to find 80-92mm convertors.
    The 80's replaced two higher airfllow (and noise) 80mm's, which ran on about 7v. The noise difference is apparant, even with both the fans running at max speed ( they are thermally controlled and may not be running at 100% however)
    The case temps have dropped considerably as well, sitting at 23 at the moment, and the room doesn't feel any colder than usual either. (time will tell though, as the weather changes)
    So, overall, the fans get 10/10, they arrived within 5 days from the US, they are nice and quiet, and not overpriced either. Well recommended, though the only drawback is having to order them from the US...
    s
  2. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    :jawdrop: :jawdrop:
    seriously!? i have a nexus 17db running in my shuttle and thats as good as inaudible, but only moves about 20cfm.
    me looks into buying another fan to test in the shuttle....
    RoB
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    where did you buy them from?
  4. Carbon
    Carbon Banned
    8 Jan 2003
    yes, where did you get them :D
  5. Highland3r
    25 Jul 2003
    they are from http://www.silenx.com.... email them (think me mate did) and they were all to happy to help... as i say , we've paid no VAT or import duty yet, and postage isnt too steep (think it was ~ 10-15 quid)
    *might* be selling the 92 and 1 120mm on, unless i can find some converters of decide to build another rig soon.....
  6. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Are these the see-through jobbys? I seem to remember seeing (not that long ago) a review of them and a link to where you could get them in the UK, but I can't for the life of me remember where...
  7. Highland3r
    25 Jul 2003
    No they aren't.. will psot some pics in 2 secs :D There is a UK site that sells/sold a small selection, (the 80mm's i think) but it was cheaper to order from the US i believe....
    thats the 92 and a 120mm
  8. Kameleon
    29 Apr 2003
  9. Xen0phobiak
    8 Aug 2002
    Same here, I prefer it to be manual, or at least controlled by the mobo.
  10. Highland3r
    25 Jul 2003
    Dont like thermally controlled ones usually but they were cheaper! If i hack off the diode and solder the wires together will they run at full speed?
  11. Xen0phobiak
    8 Aug 2002
    should do yeah, describe/take piccys of the wiring for us tho.
  12. Kameleon
    29 Apr 2003
    Or you could just stick the thermistors next to/in something very hot...:D
    Hot water cooling! :rock:
  13. Highland3r
    25 Jul 2003
    Like the "hot place" idea.
    Erm there *appear* to be one wire going to power, (black wire) and another to a point next to is with no other wires attatched....
  14. Xen0phobiak
    8 Aug 2002
    could you ellaborate a bit? is the thermistor inline with the power to the fan, or does it come on a seperate pair of wires from the fan itself?
  15. Highland3r
    25 Jul 2003
    sorry.. erm seperate wires from the fan.
  16. Xen0phobiak
    8 Aug 2002
    should be fine, take note of which way round the thermistor is though just in case, I dont think they are directional, but it saves some soldering if it all goes pearshaped.
  17. Highland3r
    25 Jul 2003
    ok will do :D thanks :D
  18. overfloe
    overfloe What's a Dremel?
    17 May 2003
    man these fans rocks hard! i sense a bulk order here :p
  19. Highland3r
    25 Jul 2003
    IF theres enough interest, my mate and me *may* go into business selling these fans, depends on whether people will be willing to buy them or not.....
  20. overfloe
    17 May 2003
