Scratch Build – In Progress Silent Blue CaseCon (18 July Update)
Discussion in 'Project Logs' started by sik19, 21 Aug 2007.
  1. sik19
    sik19 What's a Dremel?
    2 Jan 2006
    Hi Folks,
    today i post my new Worklog, well new..... it started 11.8 so its nearly new.
    It will be a Casecon made of Alu (3mm thick to be precise) with some blue accents.
    Before i started, i made a Sketchup drawing (took my around 24h to finish) which is my biggest and most accurate work with sketchup til now. But im not gonna show it to you, at first. I will post only small pieces with the parts im working at at the moment.
    Phu... lots of describtion ;)
    Now lets start with the first piece.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    After that i continued with this two little cuties
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    Phew... thats it for today. I hope its not too much, but i even let a few pics out. This is whyx i said 56k warning, right? :D
    Well one thing, the pictures are not in the right order judging from the date. I pit the into groups so its easier to read.
    The last thing i worked on was actually the "sik" Letters.
    Im looking forward to your comments.
    More to come....
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Normally I h8 blue as an accent but here it looks pretty good. Go cheesecake :D
  3. Teyber
    Teyber ******
    18 Mar 2007
    whoa! thats awsome there! how did you get the blue inside of the supports? and how much were those things!?!?
    great mod, ill be wtaching!
  4. sik19
    2 Jan 2006
    Thanks.
    I have some pices of how i made them, didnt included them into the first post( thougt it would be too much). But here they are for you ;)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    The Supports were originally a 10mm x 10mm x 1000mm alu bar.
    Here you can see my first "prototype"
  5. Teyber
    Teyber ******
    18 Mar 2007
    ah.
    i can tell this isn't your first mod :D
  6. sik19
    2 Jan 2006
    Woha you are right :D
    This were my previous ones
    [​IMG] [​IMG]
  7. HeXeN
    HeXeN Straight from Hell
    14 May 2006
  8. sik19
    2 Jan 2006
    Thats just some blue acrylic. I used two different holesaws and so i got it.
    I hope thats what u meaned?
  9. HeXeN
    14 May 2006
    ohh i didn't see edges of acrylic sorry. First thing that went trough my head was foil filter <stupid me :D>
  10. TNash
    TNash What's a Dremel?
    12 Mar 2007
    Wow, this looks really cool. Can't wait to see what the whole case is going to look like.
  11. Teyber
    Teyber ******
    18 Mar 2007
    whoa! your previous mods are crazy! welcome to the forum btw. Nice work!
  12. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    this is looking superb!
    keep up the great work
  13. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Nice work mate, can't wait till see some more updates...:D
    How thick is alu plate?
  14. lisimengok
    lisimengok What's a Dremel?
    26 Jul 2007
    nice CaseMOD
  15. Lupo_IM
    Lupo_IM ItaliaModding staff
    30 Jul 2007
    wow!!! great works man!!! ;)
  16. sik19
    2 Jan 2006
    Update 22 Aug.
    @Cyberbob:): The Alu is 3mm thick.
    Thanks for your nice comments. Therefor i have a new update for you.
    I continued working on the right side panel. I cut the plexi for the small window. Sorry i have only one pic of the progress, then was the cam empty.
    Well here is the pic:
    And the Result:
    Looks ok at first sight, but when you look closer...
    [​IMG] [​IMG]
    You can see that one edge broke. And thats when i was so close to finishing it :wallbash:
    Well cant help it, i had to redo it. But the second try wasnt better, it broke even earlier. When i wanted to drill the holes for my jigsaw an edge broke too.
    Then with the third try it worked, but now im out of acrylic :duh:. But fortunately i ordered already some new, which should arrive shortly.
    Well here is the result:
    [​IMG] [​IMG]
    And another thing happened today. I got a parcel with my new Motherboard. It it a micro-ATX Board which is kindly provided by Foxconn. It is the 45CM-S.
    Thats it for today.
  17. ComputerKing
    8 Sep 2006
    WOW! OMG DAM. This is crazy amazing case! WOWOWO I love it too much. This is what I'm talking about. Well done. Nice Job.
    good luck and Update Please!
  18. sik19
    2 Jan 2006
    Thanks man and heres your Update ;) though its only a small one.
    Today i worked on the Mainboardplate. As you can see its far too big.
    So i had to cut it down to a more suiting size. I marked roghly where i had to cut and the fun started ^^
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    No it fits perfect in the case, exactly what i had in mind.
    See you next time.
  19. ComputerKing
    8 Sep 2006
    WOOT :D very small mobo :D well done buddy Well done, I can't wait to see it done, Amazing. good job.
    Good luck buddy.
  20. KaotiK
    KaotiK What's a Dremel?
    2 Jul 2007
    Looking great!! :thumb:
