Scratch Build – In Progress Silent Blue CaseCon (18 July Update)
Discussion in 'Project Logs' started by sik19, 21 Aug 2007.
  1. BigPoppaJNutZ
    BigPoppaJNutZ Beyond the Dremel...
    14 Feb 2008
    NICE, looks great!
    If you don't need the U channel for any type of electrical insulation:
    If you have extra mesh, you could make your own U channel out of it to keep the style the same, but maybe paint it different for accent. Also, you could make U channel with some really thin gage sheet metal and just polish it up... It would take some work, but it looks like you have the patience for it!
  2. sik19
    sik19 What's a Dremel?
    2 Jan 2006
    Hmmm nice Ideas BigPoppaJNutZ. Never thought of sth like that. hm.....
  3. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Yeah, u-channel is rubber.
    @ Sik19: Beautiful work, man.
  4. BigPoppaJNutZ
    14 Feb 2008
    U Channel can be made from all kinds of materials. Rubber, glass, wood, metal, composites...
  5. E.E.L. Ambiense
    26 Jul 2007
    LOL. Splitting hairs, man. I meant in this particular use (i.e. computer modding) it would more than likely be rubber. ;)
  6. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    nice work ...
  7. sik19
    2 Jan 2006
    Thanks guys, i´ll see what i´ll use in the end
  8. Anakha
    Anakha Minimodder
    6 Sep 2002
    DANGER, WILL ROBINSON!
    The first two connectors are NOT wired the same as the second two.
    The two on the left are wired:
    Code:
    Yellow     Red
    Yellow    Black
    And the two on the right are wired:
    Code:
     Red      Black
    Yellow   Yellow
    I am making the assumption that all the connectors are the same way up. If so, DO NOT use this 'til this has been corrected, please.
  9. sik19
    2 Jan 2006
    Thanks man, but dont worry the first two connector are for S-ATA :)
    But you are the first one who said sth. about the different wires
  10. Fused
    Fused Minimodder
    19 Jun 2007
    Ive looked at those photos a few times and ive not noticed it, each time im just impressed by the neat and tidy arrangement of the wires :hip:
  11. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    me2 Fused :D
  12. sik19
    2 Jan 2006
    pssst.... im a trained electrician so its not really a big deal :D. But thanks im glad to hear that
  13. Jipa
    5 Feb 2004
    I'm as well and yet I managed to blow up an old rig by wiretricking a fan adapter... R.I.P.
  14. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    :) huh if you're trained electician you don't need colours :) you just know the scheme ;P... but trully it helps a lot. good job Sic19!!
  15. sik19
    2 Jan 2006
    @Jipa: Everyones can have a bad day some time.
    But i need your opinion guys.
    Im thinking to paint the inside (only for the side where the mainboard psu etc. is) black, then i want to sand the mainboardcover down to blank metal and paint some shapes and a logo on it. What do you think? could this look good? Im not quite sure, but i think it wont look too bad.
  16. sik19
    2 Jan 2006
    Hi guys, long time no see.
    The last few months i've had much to do for university nad stuff. But now are the first exams over, and untill the next ones, i have lots of freetime.
    So today i had actually to look for my case con, where did it hide.
    Eventually i found it under the stairs ^^
    So i started the operation "Rescue the Con" and the case transfered into my room (which i has been cleaning for the last 2 days) safely.
    After that i looked at the case and thougt "What to do next"
    First
    -> away with the motherboard cage, i dont need that
    Second
    -> definetly no paint on the outside.
    The rest of the remaining day i spent, giving the plexi parts their final polish. In the end it was only one part, and only half of it :-/
    Well here are the first pics after a long time from me.
    Right from under the stairs:
    [​IMG][​IMG]
    And the plexi part i was polishing (one of the front thingies)
    Before:
    [​IMG][​IMG]
    After:
    [​IMG][​IMG]
    I've spent a full hour for this ( i sure got rusty ^^). The next updates will be filled with more polishing im afraid, but i have to start slowly after such a long break. ;-)
    Until next time
  17. sik19
    2 Jan 2006
    Hey guys,
    today i could continue a little.
    And again,
    before:
    and after:
  18. Cheapskate
    13 May 2007
    Good to see you back.:D
  19. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Yes, it's definitely nice to see a new update on this bad boy. Extremely clean polishing work...man it's so worth it to take the time and do that. :thumb:
  20. sik19
    2 Jan 2006
    Hi Guys, good to be back :)
    Thanks.
