Silicium by Schimat
Discussion in 'Project Logs' started by Schimat, 12 Feb 2012.
  1. Schimat
    Schimat What's a Dremel?
    12 Feb 2012
    Hello everybody, this is my first thread on this awesome site. I'm italian, so exscuse me if I don't write English so good. I'm nineteen years old and now I want to show you my mod. The name of the mod is Silicium and he's partecipating to Mod'N'Roll 2012 competition. Look at this little picture (a sort of project)
    I'm going to up other pictures about my work. See you soon, stay tuned :D
  2. Schimat
    12 Feb 2012
    These are spheres of polystyrene that will be the principal structure of the "case"
    Yesterday I cut one sphere and I insered the optical drive into her. This is the result:
    The free spaces will be covered whit some plexiglass.
  3. Schimat
    12 Feb 2012
    I changed the hardware purchasing a mini-itx mb (17x17cm) AM3. Meanwhile, I prepared the base plate of the motherboard deriving it from an old case.
    Here are the new arrivals
    The larger sphere is 30cm, the other from 20. Then I got 2GB of DDR3 and the rest will come later.
  4. Schimat
    12 Feb 2012
    And this is the motherboard
  5. Schimat
    12 Feb 2012
    I think I found a good solution to mount the power supply and the motherboard in the central sphere. In this picture I show you the case of the power supply with mounted above some pins stolen from an old vga
  6. Schimat
    12 Feb 2012
    Here's the newcomer after a week of travel. Thanks to the post office for the speed
  7. Schimat
    12 Feb 2012
    I only did some work with the resin. I started with the central sphere. I covered with parcel tape and have spread within three pieces of glass fiber cross between their brushing them with the resin.
  8. Schimat
    12 Feb 2012
    Here are some pictures to give you an idea of what will come out. In this picture there isn't the base of my mod. The tubes that you see have a diameter of 4cm.
  9. Schimat
    12 Feb 2012
    Here are some up to show you that I'm covering a hemisphere of fiberglass. For now I'm trying, I hope to be good. I covered the hemisphere with a sheet of fiberglass and now I have stretched a little to the fiberglass filler to smooth the surface, and then paint it.
  10. Schimat
    12 Feb 2012
    Today I continued to cover the fiberglass and the other half of the ball and rub each other. Meanwhile I did some tests to decide how to place the ball. Unfortunately it is all a bit wrong because the pipes are not fixed so they move constantly. But at least I got an idea. It seems to me that we need more distance between the spheres. What do you think?
  11. Schimat
    12 Feb 2012
    Hemispheres ready for the treatment ;)
    And these leds will light my mod
  12. Schimat
    12 Feb 2012
    This is the support for hdd 2.5". I do not know where the piece of plastic comes from, I found it in my garage. That green rubber is to reduce vibrations and i got them from the inside of an old cd player.
  13. RealWeaponX
    RealWeaponX What's a Dremel?
    16 Mar 2012
    unusual design... subbed.
  14. Schimat
    12 Feb 2012
    Oh yes, very unusual :D
  15. Schimat
    12 Feb 2012
    Here is the first hemisphere. The result is still not good, it seems that the sphere has cellulite
    I'm using to close the tiny holes that are a lot of white glue mixed with talcum and a few drops of water.
  16. Schimat
    12 Feb 2012
    Here are a few up
    Today I mounted the plate resting on the power supply mb card to see that everything was in place
    And, what is this??
  17. Schimat
    12 Feb 2012
    Today I searched into the drawers something that I can use to block the tubes. I want something that blocks the tube inside and outside otherwise the excessive weight would collapse. And here is what I found, the effect does not seem bad but still did not convince me at all
  18. Schimat
    12 Feb 2012
    I continued to fill the balls and now I miss a little ball and the big one. Meanwhile, I prepared a kind of grid to let the air out from the last ball, one at the top. The grid will be completed after grouting and do not see why it is on the back of the ball.
  19. Schimat
    12 Feb 2012
    First tests of paint whit "Nordic blue micaceous"
    And a little test whit some leds
  20. kenco_uk
    28 Nov 2003
    Wow, this is very unusual! Props for having the balls (haha) for doing something like this :D
    I'm keeping my eye on this one :thumb:
