Watercooling Silver Coil in watercooling???
Discussion in 'Hardware' started by Siwini, 24 Jun 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    New to watercooling. Just finished installing my first RS240 kit, but forgot this. Can someone tell me what this thing is and what its for anyway? Thanks in advance.
    Ratchet219 likes this.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    It stope things growing in your fluid if your using plain water :)
  3. jamsand
    jamsand Minimodder
    21 May 2011
    kills off algae and nasty stuff growing in your loop
  4. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    As above, you should put it in. :)
  5. Siwini
    14 Sep 2010
    Even if I'm using Feser one?
  6. Bloody_Pete
    11 Aug 2008
    Not if your using that, as it has chemicals in it to do it :)
  7. Siwini
    14 Sep 2010
    Will it be ok 2 put in anyway? Bottle said not to mix anything so is it safe? As far as thermal paste go use one that come with kit (white not labeled stuff) or use GO2 from GELID? I got both.
  8. brave758
    brave758 Minimodder
    16 Apr 2009
    wasn't this covered in your flushing rad post?
  9. darren1678
    darren1678 What's a Dremel?
    20 Jan 2007
    i wouldn't bother eighter last time i filled my old loop i did it with a couple cap fulls of bleech
  10. Bloody_Pete
    11 Aug 2008
    Bleach can react strongly with some pf the metals and plastics though...
  11. darren1678
    20 Jan 2007
    i ran with bleech for six months before refilling no problems discovered altho i didnt use it again because i actually had money this time round :D
  12. Cyndre
    Cyndre What's a Dremel?
    12 Apr 2010
    If you are using an EK Nickel block they suggest not using the coils or biocides and opt for ethylene glycol.
    Edit: If just the kit and no extra cpu block then just ignore :) I saw good things about using Mayhems biocide.
  13. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
