Case Mod - In Progress Silver Dragon "Video" Pag22
Discussion in 'Project Logs' started by ulysses Cazuquel, 1 Apr 2007.
  1. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    I gotta agree with Nut. Personally I love the way copper looks, but in this instance especially considering the name of your mod I would definitely look into plating
  2. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    Thanks Nutman and sixfootsideburns!
    I had this initial idea but now I will best analyze
    I love these DangerDen blocks painted ​​by Xion X2
    http://forums.bit-tech.net/showthread.php?t=176663&page=12
  3. ulysses Cazuquel
    29 Apr 2006
  4. PAL
    PAL New Member
    27 Apr 2011
    impressive hardware and one beautyfull case !:thumb: can't wait to see the end results
  5. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Very nice. Now go and get those graphics blocks nickel plated, and you're on the right path. ;)
  6. ulysses Cazuquel
    29 Apr 2006
    PAL
    Thank you, now the final adjustments to mount my project
    Thanks Nutman
    I am negotiating blocks nickel plated for my motherboard and after I will send my blocks of vga and cpu for nickel plated
    Now a picture of today with the dual radiator Phobya G-Changer 280
    What is the opinion of you?
  7. Nutman
    21 Oct 2008
    It seems like the weight of those 2 rads is putting quite some strain on the UV green acrylic shroud. Perhaps you should install some spacers in the lower fan threads on the inner radiator? These spacers should help the radiators sit vertically perfectly aligned with the back of the case.
  8. ulysses Cazuquel
    29 Apr 2006
    Thanks Nutman!
    I created a adaptation for my UV green acrylic shroud and the result is very good.
    With these adaptation, I can put my radiator in any position that is very important for my project.
    Also today I created a adaptation to keep the radiators in vertically perfectly aligned with the back of the case and I will use when I mount my project
  9. Nutman
    21 Oct 2008
    Just read through the whole worklog - didn't realise until now that you've been working on this for more than 4 years. Wow.
    I feel silly for making this suggestion (again), but I still think you should put the external stuff (radiators and reservoirs) somewhere on the inside. Maybe you could mount the radiators on their sides BELOW the entire case and make some cool, long (dragon's)feet to replace the ones you already made? I just think the project as a whole would benefit from and be much better balanced if all the external stuff was somehow put inside the outer borders of the main structure.
  10. PAL
    PAL New Member
    27 Apr 2011
    Maybe a box with the same dragon style window underneath the case or side by side could hold those rad and fan it would be a lot more work but it would ad a lot:cooldude:
    love those dragon
  11. ulysses Cazuquel
    29 Apr 2006
    Thanks Nutman and PAL!
    This my project not was made ​​to use a system WaterCooler, then any accessory to adapt my system Watercooler is very difficult
    In Box that I did to power supply not have space for my radiators
    The news today is that I painted my Water Block GPU of black
    It's pretty good because now has the contrast Water Block GPU of black with the chrome Bitspower Compression Fitting and the Phobya ZuperZero UV Yellow
    Anyone have pictures of other blocks painted in the internally part ??
  12. Nutman
    21 Oct 2008
    You painted it, instead of having it nickel plated? Not sure if that's such a good idea, as you don't know if the paint will dissolve into the cooling fluid over time, causing possible clogging of the loop - also, it has to somehow impact the cooling ability.
  13. ulysses Cazuquel
    29 Apr 2006
  14. Nutman
    21 Oct 2008
    This is still in a league of its own - really, really cool!
  15. Watchtown
    Watchtown New Member
    2 Mar 2010
    My kind of porn, gorgeous build!:rock:
  16. ulysses Cazuquel
    29 Apr 2006
    Tomorrow I'll post another video of my project
    More Two pictures from today
    Tomorrow I will also reply to comments
  17. ulysses Cazuquel
    29 Apr 2006
    Thanks Nutman!
    After I will nickel plated the blocks of the VGA and CPU :rock:
    Nutman
    Now I will finish my project in 2 week because it came the motherboard
    Thanks Watchtown!
    Sex, Casemod & Rock'N Roll :dremel: :rock: :jawdrop: :clap:
  18. ulysses Cazuquel
    29 Apr 2006
    More some photos of my project.
    I'm analyzing to change some few details of the front of my project
  19. Nutman
    21 Oct 2008
    Beautiful, beautiful...
  20. ulysses Cazuquel
    29 Apr 2006
    Thanks Nutman! :rock:
