silver kill coil?
Discussion in 'Watercooling' started by Yaka, 30 Jan 2018.
    Yaka Well-Known Member
    26 Jun 2005
    planning a loop for my pc. is silver kill coil still recommended? its only consisting of old EK rad, ek d5 revo/res, ek socket 2066 cooler , mayhems tubing and mayhems xt clear liquid.
    my last build few years ago i used kill coil with mixed metals nickel block gpu block, copper cpu block and some of the tubing that was apparently leecing plasterriser
  2. TheMadDutchDude
    23 Aug 2013
    Do they recommend it with that fluid? Check the website. If it doesn't, then don't worry. Are you mixing metals again?
  3. cobalt6700
    cobalt6700 Active Member
    17 Oct 2005
    AFAIK Mayhem's has corrosion inhibitors and biocide so no silver coil needed :thumb:
  4. Yaka
    26 Jun 2005
    cool, and not ever gonna be mixing metals again this loop is for cpu block. gpus will be a seprate loop at a later date.
  5. cobalt6700
    17 Oct 2005
    You shouldn't ever mix ally and copper - but nickel and copper are just fine :thumb:
