Hardware Silver Power SP-S850 PSU
Discussion in 'Article Discussion' started by Tim S, 26 Sep 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. tonschk
    tonschk What's a Dremel?
    31 Jul 2008
    Excellent review , I agree the heatsink looks small but each heatsink have many thin fins to improve dissipation, I like also because is not modular , was better if made with the single rail configuration
  3. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Beware of Silver Power's psu's! We get Silver Power's various psu's alot at work (Komplett's returns department), and they've got a nasty habit of blowing up in your face. We get alot of them, and they're all pretty much the same. Some arent as loud as some others and some are worse.
    They might be good when they're working, but they're a nightmare when they work. Do not buy!
  4. Guest-16
    Guest-16 Guest
    Interesting! How do they blow up? Which models exactly?
  5. Jokkocze
    16 Dec 2004
    I've got no idea what the models are called, if they have any name at all, but we get their 500, 600 and 850w psu's. Usually 2 or so per day, but sometimes more and sometimes less.
    Their blowing up quite dramatic, compared to others (that I've seen). There's usually one loud bang and then a few quiet ones, while there's sparks flying, or something else that's really bright, around inside the psu. It's not uncommon that the protective cover (really no idea what the case is called) gets electrified and shocks you when you try to switch it off. A guy got a quite powerful shock from one, and got some burns on his hands when he were shutting one off.
    If there's anything else you're wondering, you're welcome to send me a pm instead ;)
  6. wbdog206
    wbdog206 not me
    15 Jan 2007
    i have had more deer psu's drop dead on me
    than any other brand!
  7. Guest-16
    Guest-16 Guest
    Wow, well thanks for your valuable input!
  8. tonschk
    31 Jul 2008
    The Manufacturer is Tagan , I must check this info
  9. Nanopoint
    Nanopoint What's a Dremel?
    30 Sep 2008
    Greetings all.
    These comments made by Jokkocze are very odd, as compared to the amount of system builders who purchase SilverPower from us, we have had no complaints on quality of these power supplies and a returns rate of less than 1%.
    Jokkocze has stated that the 500, 600 and 850w psu’s all fail, however the new series of SilverPower have only been on sale for the past month. The comments given do appear to be a direct attack to tarnish the brand name.
    I can assure all readers who have a SilverPower psu or those whom are planning to buy a SilverPower that they have nothing to worry about, these are high quality products as you will see from previous & future reviews.
  10. Guest-16
    Guest-16 Guest
    Thank you for your input and a balancing of the opinion :) :thumb:
Tags: Add Tags
