Case Mod - In Progress Silvermist // A PhantomGaming build
Discussion in 'Project Logs' started by CustomRigs, 28 May 2019.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    SILVERMIST
    Hello everyone here is a new Worklog from me for you :)
    First i have to say thankyou to the supporters ! Without the support it wouldnt be possible !
    Asrock, Cooler Master, Team-Group, AMD und EK Waterblocks ! Thank you !
    In this build io want to integrate my personal note but want destroy the phantom gaming design.
    Hardwarespecs
    AMD RYZEN THREADRIPPER 1950X
    ASRock X399 Phantom Gaming 6 Mainboard
    32GB Teamgroup Xcalibur 3200MHz quad Kit
    ASRock Radeon VII
    Cooler Master H500P Phantom Gaming
    Cooler Masteer V1000 PSU
    500GB Teamgroup Delta RGB SSD Phantom Gaming Branding
    M.2 SSD TBA
    EK Waterblocks Velocity TR4 CPU Block
    EK Vector Radeon VII GPU Block with nicklebackplate
    EK WB XTOP Revo D5 RGB PWM
    EK Coolstream PE 360 two of them
    13 EK WB Vardar EVO´s RGB PWM
    EK WB fittings and extensions in silver
    RAINPOW RGB controller
    Planned till now is : Topcover for the topfans, 16mm Hardtubing, Custom CNC Reservoir with a phantom gaming design. Custom acrylic design elements !
  2. Cpt.Zakhar
    Cpt.Zakhar What's a Dremel?
    25 May 2019
    So many good component, I'm looking forward to this build
    CustomRigs likes this.
  3. CustomRigs
    8 Dec 2017
    After a long time my lasered parts arrived :/ waited alot on this ... never order again at this guy !
    But the quality is nice !
  4. CustomRigs
    8 Dec 2017
    Some steps further :)
  5. CustomRigs
    8 Dec 2017
    today i got the new EK WB Torque fittings ! and quantum line angles !
    They looking dope ! Also im waiting on dhl of the arrive from the last tubes ... have to do one laqst tube with four bends in one tube ...
  6. Cheapskate
    13 May 2007
    Love the layered plexi/metal look. :D
  7. CustomRigs
    8 Dec 2017
    thanks :) yeah i like it to :D
  8. CustomRigs
    8 Dec 2017
    finished :) hope you like
  9. CustomRigs
    8 Dec 2017
  10. kim
    kim hardware addict
    10 Jan 2016
    Beautiful result, :thumb: I love those EK fittings and the frosted tubes effect, great bending job as well
  11. CustomRigs
    8 Dec 2017
    Thanks alot ! Yes i like the frosted look :D
