Hardware Silverstone Fortress FT01
Discussion in 'Article Discussion' started by Tim S, 20 Oct 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. The boy 4rm oz
    10 Apr 2008
    Looks very nice, a very worthy blank canvas. Personally I would rather have 120mm fans all round than the 180mm fans, they are easier to replace if they die. Plus it makes mounting a radiator easier.
  3. Jipa
    5 Feb 2004
    IMO you could have should have tried to turn the top fan around to make it an exhaust? Might make some interesting changes to the results...
  4. karx11erx
    karx11erx What's a Dremel?
    17 Dec 2004
    How about this: Reverse the top intake fan orientation to make it extract air from the case - will solve the problem of the single 120mm exhaust fan being too weak and allows to remove the top dust filter. ;)
  5. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    is it just me who thinks the looks of these cases are distinctely meh?
    maybe it looks better in black but the silver looks tacky to me
  6. Chr!s
    Chr!s What's a Dremel?
    21 Apr 2004
    £150 is a bargain case?
    lol
  7. Tim S
    Tim S OG
    8 Nov 2001
    For a Silverstone it is!
  8. Chr!s
    21 Apr 2004
    You can go to some eastern europe city for a weekend for that much dosh! Its crazy I tell Ye! :lol:
  9. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    What a shame that they spoiled the ship for a ha'porth of tar... Although I too would have thought that exhausting out of the top fan might work better.. it would be interesting to know how that would affect that overall case performance.
  10. Tim S
    Tim S OG
    8 Nov 2001
    I've spoken to several case manufacturers this morning about your claims--that use all of the various hard drive orientations--and none have said that this orientation is inferior in terms of cooling performance.
  11. naokaji
    naokaji whatever
    8 Dec 2006
    A HDD orientation like in the FT01 does have the advantage though that you can remove / add HDD's even with long graphicscards installed that would get in the way if the HDD's would be the other way.
    Also aslong as they cut big enough holes in the hdd "box" cooling shoudnt be a issue.
    150£ for a midi tower that doesnt even have a removable mobo tray? no thanks, as much as I love the external design, I'd rather pay 20£ more and get the best case ever (lian li a77) or save a big sum and just get a cm 690 instead.
  12. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    I had very high hopes for this case.
    Shame really since Silverstone do make great cases. Cooling is much worse than I expected however I really think as part of your testing that you should have reversed the top intake. Many other sites reversed the fan's whilst reviewing the TJ07/TJ09 and experienced vastly different results.
    When are peoplegoing to stop harping on about the orientation of hard disks....STOP! Should a case manufacturer decide to invest $$$,$$$ on R&D and deem their design sufficient to pass Q&C then you should rest assured that all will be well. Lian-Li did it back with the V1000 series. How many Lian-Li cases do you see stuffed with HDD's??? I have a TJ09 with 5 HDD's and no failures. It really is not an issue so shut up about it!
    Apart from my rant's, another nice review BT. This was going to be my new case but I guess I should wait a while, this is screaming at me for a Crysis/Far Cry 2 inspired mod......hmmmmm!
    Do Coolermaster realize how much they would make with an updated Black Widow? Update should be front, rear and top 120mm mounts, 6 drive bay's instead of 4 to mount radiators if your so inclined and a top and bottom PSU mount....They would clean up with that design!
  13. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    <- silverstone fanboi.
    i love the looks of this case and a little downfall here n there that i can fix is not a deal-breaker.
    and yes, looks like a great canvas. i prolly pick this one up for my girl....
  14. kenco_uk
    28 Nov 2003
    The top fan needs to be in a plastic cradle, secured either by a push clip or two or maybe even a single screw that's easily reachable.
  15. Baz
    Baz I work for Corsair
    13 Jan 2005
    The orientation doesn't make a blind bit of difference, but I agree that the distance between drives certainly does.
  16. Jipa
    5 Feb 2004
    Who REALLY needs 7 HDD bays in a normal desktop computer anyway? After all 3 HDDs can be installed so that there's an extra bay between each of them... HDD-bay designs are always compromises between number of drives and amount of wasted space. If you had a couple of nicelyt spaced drive bays in a case like this then people would come ranting about not having enough bays :)
  17. fathazza
    fathazza Freed on Probation
    20 May 2002
    bah, this case was on my shortlist :(
    now it isnt... Gonna have to wait to see how much the coolermaster atcs 840 is when it hits the shops
  18. Saivert
    Saivert Minimodder
    26 Mar 2005
    Well... for those who can't afford 1TB or even 1.5TB drives, you end up with a bunch of hard drives.
    I own a Lian Li PC-101B case which is filled with 7 harddrives. I had to buy an extra Lian Li drive cage because the six drive slots was not enough.
    Most reviews even these on Bit-tech only test the cases with a minimum of required stuff for a computer. That is MAX 1 HDD, 1 graphics card, no extra PCI cards (RAID controllers etc), only 1 DVD burner (many have two or a Reader+Burner setup).
    Time to do some stress testing of the case as well and try to see how much stuff you can really fit while still keep it tidy. I'm sure most of the midi cases will fail miserably. It does not look pretty inside my Lian Li case.
    A picture for those who may be in doubt:
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    hmm not as impressive as I thought it was going to be...
  20. samkiller42
    25 Apr 2006
    Like Silverstone cases, Don't like that front I/O location, still, i like my TJ07W far too much to want this
    Sam
Tags: Add Tags
