Cases Silverstone FT03 build (now turning into post your pics of FT03 builds thread)
Discussion in 'Hardware' started by Lankius Maximus, 8 Feb 2011.
  1. Cei
    Cei pew pew pew
    22 Mar 2008
    longweight, sorry! It's the LN27294 item on Scan, or the Akasa AK-CB050. The forums didn't parse the ) at the end of the link.
    longweight likes this.
  2. longweight
    7 May 2011
    No worries! Thanks a lot :thumb:
  3. Huge
    Huge aka Dave
    11 Jul 2011
    Posted in your thread too, thought it might help someone here so I'll repost here as well.
  4. Huge
    Huge aka Dave
    11 Jul 2011
    In case anyone's considering it I can report that an H-50 definitely does fit into the FT03, very comfortably. Now I can have as much vengeance RAM as I like and overclock the nuts off my CPU without worrying about it :)
    Now my CPU is water cooled :) Haven't done the stress testing yet but when idling the temps have from down from a delta T of 10 to 7.5 :)
  5. Hutchy
    Hutchy What's a Dremel?
    7 Jul 2003
    Does anyone know what we can expect from the new Titanium version coming out in a couple of weeks?
    Worth waiting for since they are the same price?
  6. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Pretty sure it's just a new finish/colour option.
  7. Huge
    Huge aka Dave
    11 Jul 2011
    In case anyone is interested there is a thread with a modified FT03 here, he takes it apart and paint some parts, the overall job doesn't really modify the case a huge amount but it makes an interesting read. Good idea for rerouting the power cable too, going to try that out tonight.
    Anybody know if it matters which way around you mount the H-50 CPU cooler? I have mine with the writing the right way up but in the above thread he mounts it sideways (as it would be in a normally aligned case). My temps seems fine but I wondered if they'd be better set up as he has?
  8. Iskra
    Iskra What's a Dremel?
    1 Apr 2011
    15 months after beginning my build it's finally ready.
    Silverstone ft03
    Asus Maximus IV genez
    Intel 2500k
    2x4gb corsair vengeance 1600 lp lv
    Asus Gtx 560ti directcuII top
    Corsair Hx650
    Corsair H60
    Optiarc slotin dvdrw
    Intel G2 120gb ssd
    Now i'm a happy camper...
    :rock::rock::rock:
  9. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    Very nice.
    But they still have not updated the USB3 to the internal header? :miffed:
    Want to get one myself but would prefer to have my rear IO USB3 open...
  10. Cei
    Cei pew pew pew
    22 Mar 2008
    Get a board with more than two rear USB3?
    I'm still tempted to get a H60 or H80 for my FT03 and replace the Frio.
  11. teppic
    teppic What's a Dremel?
    18 Jul 2011
    Are the water coolers here pulling air into the case? I know that normally Corsair ones should, but I can't imagine air getting out very easily that way in these cases.
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    In an FT03 you'd have to be running it as an exhaust.
  13. Iskra
    1 Apr 2011
    I bought it when it first came out around a year ago, could't say about the newer ones.
    Also bitfenix has a usb 3.0 internal header that's compatible with this case.
    Mine is set as exhaust with the corsair working push and the case Silverstone doing pull.
  14. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    Some nice kit you got there, congrats on the build.:thumb:
  15. Iskra
    1 Apr 2011
    Thanks.
    Took me a long time to finish it but i'm proud of the result.
  16. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    So... I went to buy an FT03 today, except I didn't because the top/side panels look and feel like something from a cheap patio set.
    I am disappoint.
  17. Cei
    Cei pew pew pew
    22 Mar 2008
    I'd agree the top panel isn't exactly the best - it's plastic after all, but what was wrong with the side panels? The finish is nicely done, and rather hard wearing as well.
  18. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Oh I meant specifically the plastic side panel, sorry that wasn't put very well. The side panels themselves are things of beauty!
  19. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Thought I'd share some photos of my new WC loop inside the FT03, and put together a short guide to the simple mods required for anyone else thinking of giving it a go.
    I'd been running my FT03 on Air since purchase as a way of putting the components bought for my MacPro mod to some use (my MacPro build progress had come to a halt with all the hardware being left unused).
    BEFORE
    SPECS:
    Intel i7 950 (stock)
    ASUS Rampage Gene IV X58
    6GB Corsair Dominator 1600mhz
    MSI GTX580 TwinFrozrII OC
    1x Samsung F3 1TB HDD
    1x OCZ Vertex 2 Bigfoot 240gb SSD
    Silverstone Strider ST1000 PSU
    3 x Enermax UCCL12 Cluster 120mm Fans
    1 x Noctua 92mm
    AFTER
    SPECS:
    Intel i7 2600K (EK Supreme HF Full Nickel)
    ASUS Maximus IV Gene-Z Z68 REV1
    2x 4GB G-SKILL Ripjaw X 1600mhz
    MSI GTX580 TwinFrozrII OC (EK-FC580 GTX+ Nickel Acetal EN)
    ASUS Xonar D2X
    1x OCZ Agility 3 240gb SSD
    2 x Enermax UCCL12 Cluster 120mm Fans
    2 x Noiseblocker Multiframe S-Series M8-S3 80mm Fans
    EK XT120 120mm RAD
    Magicool 160 dual 80mm RAD
    10 x Bitspower BP-CPF-CC5 Silver Shining Compression Fitting (ID 1/2" OD3/4")
    3 x Bitspower G1/4" Thread Rotary 45 Degree Fitting Silver Shining
    1 x Bitspower G1/4" Silver Shining L-Rotary
    Tygon R-3603 ID 1/2" OD3/4" Tubing
    Phobya DC12-220 Pump
    EK Reservoir Combo DCP 2.2
    2 x Phobya LED-Flexlight 30cm
    THE MODS
    The mods are pretty simple, you'll just need a Dremal with some cutting discs and a drill bit. Start off by gutting the case (if you're not starting from fresh).
    Next, you'll need to mark out where you want to cut for the RAD, I simply put the RAD in place and scribed a line to mark where to cut.
    The orange circles show the mounting of the power socket bracket (I forgot to take a photo), it's important that those threaded holes remain. The purple (yellow in the below image) circle is a rivet that will need drilling out. The Blues lines are used only as a guideline depending on the brand/type of 160mm RAD you may need to cut higher/lower.
    Once you've marked out what needs to be removed and drilled out the rivet, take your case outside and start cutting, as three of the case sides can be removed your provided pretty good access to the cutting area.
    I'm no dremal expert but it got the job done, 5 minutes with a file and that cleaned up nicely.
    Next place the RAD in position and ensure the front edge is not sticking out further then your case does.
    Time to remove the top right bracket.
    Four rivets hold the bracket in place (don't worry the case is plenty stable without it) you'll need to drill them out (shown in yellow), the pink circles mark what you'll need to remove in order to fit the 120mm rad, you can put it back on after. For better access to the top two rivets I removed the top IO panel ( four screws and it comes free, shown in green).
    Whilst the top IO panel is off it's a good time to root your fan cable (if you choose to go push/pull).
    FITTING THE BOTTOM RAD
    The Magicool 160 doesn't share the same fan spacing as the mounts on the case, I just used two mounts from each fan with a rubber washer to help with any vibrations (sorry, no photo).
    As I was using 1/2" ID tubing with big compression fittings I knew plumbing the pump/res to the bottom rad would be tight, as a result I decided to fit my 2x80mm fans in a pull config.
    Route the fan cables out the back of the case and reinstall the power adapter bracket. The shape of the bracket allows for the extra length required by the RAD.
    FITTING THE MOBO
    That's it for mods, the rest is the normal routine, I fitted the CPU block and RAM to the motherboard and secured it inside the case.
    FITTING THE TOP RAD
    I pre-fitted the 'push' fan to the rad allowing me to use the 'pull' fan to secure the RAD in the case. I pre-installed the fittings and used TFC Xvibe Noise Absorbers between the fans and the RAD/Case.
    Fit the rest of your hardware, pump in your loop, leak test and enjoy. My build isn't finished yet, I've sent my side panel away to get a window fitted (note, the side panel doesn't fit after the mods as there is a lip on the panel for the dust filter to click into place, this connects with the bottom RAD stopping the panel from fitting).
    Couple YouTube videos are up, both are pretty early in the build process. I'll be uploading more showing temps under load whilst benching and.. well, whatever anyone would like to see.
    VIDEO 2 (Leak Testing)
    J.
    Neogumbercules and Parge like this.
  20. Parge
    16 Jul 2010
    Very, very, Veeeeerry nice work dude! Its gorgeous!
    Also, thanks for the guide, I'll probably not use it myself, but for those that do want to watercool their FT03 it'll be invaluable.
    +rep.
