Hardware Silverstone ML03 Home Theatre PC case review
Discussion in 'Article Discussion' started by arcticstoat, 28 Dec 2010.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Xir
    Xir Modder
    26 Apr 2006
    Hmmm, If you'd install something like the passive HD5450 with just the one filtered fan in the right, upper corner... that wouldn't get any airflow at all, would it?
    Have you tried looking for a less-deep DVD-drive? There's over a cm difference between brands.
  3. Guest-16
    Guest-16 Guest
    With the latest CPUs/IGPs you shouldn't really need a HD 5450 to be honest, but yes it won't get any airflow to the fins, only the back of the card.
    DVD drive: that's true, but how often can you find that information? Most people opt for the cheapest.
  4. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    It's not as nice as the Lian Li HTPC cases.
  5. Guest-16
    Guest-16 Guest
    It's also half the price of most of them ;)
  6. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Oh bit, you tease.
  7. Fordy
    Fordy Minimodder
    28 Feb 2010
    Double post.. apologies.
  8. Fordy
    Fordy Minimodder
    28 Feb 2010
    Dimensions? Most HTPC cases wouldn't $it in my rack, have to be selective!
    It's low profile, so height should be fine as i can for some full height models. But I'm still worried about the depth.
  9. Burdman27911
    Burdman27911 What's a Dremel?
    26 Mar 2007
    And I'm worried about width for my entertainment system racks. Additionally, I wish that the dvd drive was stealth and there was a mounting spot for an internal IR receiver... a man can dream.
    PS - Honestly, the GD04 case tempts me a little more than this one. It has better looks and the price isn't much more (at least in the US).
  10. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Are there rack ears for it?
    Use quite a lot of things like this building porta-puters which then get put in flight cases in order to travel around.
  11. Fordy
    Fordy Minimodder
    28 Feb 2010
    No need to worry about width, it won't be more than 19" and any non mini-model rack will hpuse 19" equipment.
    As for the UK price, Scan have it at £46.28.
  12. Xir
    Xir Modder
    26 Apr 2006
    You're right off course, I just thought in case of reusing old hardware.
    DVD Drive: wel, reading technical Specifications helps :thumb: Us users of Shuttles know all about size limitations (Pun intended) :D
    Seriously, the websites where I buy show the dimensions...don't the British ones?
Tags: Add Tags
