News Silverstone presents The Raven case
Discussion in 'Article Discussion' started by CardJoe, 4 Jun 2008.
  1. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    i like it. not that much... (i have TJ06), but still ok. and would love to try the new layout.
  2. chicorasia
    chicorasia What's a Dremel?
    8 Jan 2008
    Did anyone notice that there are NO cables whatsoever connected to the top ports on those photos?
  3. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    It has potential but I must agree.
    :lol:
    It does indeed have some advantages. I like the concept just not the implementation.
    [​IMG] I see 2 at the top back. I imagine there is a door on top with a cable chase below that
    I've thought of making such a case - but with a minimalist look (the look isn't to my taste either but I wonder what a good modder could do with it). The biggest problem I saw was that the cable chase at the top would require too much space for the cables to bend (effectively making the case bigger) and in some situations may require longer cables.
  4. knyghtryda
    knyghtryda What's a Dremel?
    2 Jan 2006
    too much plastic. It looks like they were trying for a Reventon look, and took the cheap route. The flipped mobo is interesting, though unless they provide some 90 degree adaptors for DVI/USB its gonna be ungainly to route the wires out the back.
  5. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    okay so why is this called the Raven? What in its design would have it be given such a name?
    So this is like taking the BTX idea but implementing it for AT? Interesting but routing those cables I think would become a pain in the ass.
  6. Jipa
    5 Feb 2004
    Looks like a stealth fighter jet. Lame name and I don't really like the external looks of it, but the funky internal design seems interesting enough.
    What's taking so long with the first review?! ;)
  7. Horizon
    Horizon Dremel Worthy
    30 May 2008
    it makes sense cooling wise, by rotating the motherboard the hot components are no longer stacked and heat can easily vented up and out by fans or just plain ol' convection but but doesn't override but in the end that case is just damn ugly
  8. Horizon
    30 May 2008
    @tile
    well then if you do not like it then do not buy it or build your own
  9. confusis
    confusis Kiwi-modder
    5 Jan 2006
  10. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Hmmm, interesting. I'm not that big on it, but I am glad someone is looking beyond the same stale ATX design. I would rather have the "back" of the motherboard in the front behind a door with a cableway to the back so plugging stuff in didn't involve getting at the back of the case. My dream case would be a double width one with the drives on the left and the mobo on the right with the ports facing the front, but set back 4 inches or so and behind a door.
  11. Xir
    Xir Modder
    26 Apr 2006
    Using natural convection only works if the case is very open. which brings us to two problems:
    Before abandoning the idea of making a watercooled case (due to going to LAN's i didn't want to lug the case around) i toyed with this layout. albeit the board was turned -90°
    idea, cables out the bottom, the entire top is the radiator. The entige case works as a chimney, cold air comes in the bottom, warm air rises and goes out the top.
    Combine with a LARGE radiator (entire casetop and some big fans, that only turn on at certain temperatures) and you've got a very quiet case.
    Problem 1: Most cables are too short for this. and you get an annoying lot of cables on the bottom.
    Problem 2: the case needs to be very open, so you get dustproblems and hear the harddrives.
    For this case: as the cables aro out the top, they should be long enough, but ugly. so they added a cablecanal. which disturbs natural convection.
    Good to see someone question ATX though.
    Still don't understand why the hot part of the graphicscard is usually th lower side though ;-)
  12. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Because Blackbird was already taken. :D
  13. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Masterp posted a video overview of the new Raven case yesterday :thumb:
  14. HourBeforeDawn
    26 Oct 2006
    sweet, it actually looks pretty moddable, cant wait to get my hands on ^__^
  15. tominated
    tominated What's a Dremel?
    28 May 2008
    i don't really mind it. and i hate most of those styles cases (i mean you, thermaltake!)
  16. mnpctech
    21 Apr 2003
    You're getting one HBD? :dremel:
Tags: Add Tags
