Hardware SilverStone Primera PM01 Review
Discussion in 'Article Discussion' started by Dogbert666, 28 Jul 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. David
    7 Apr 2009
    Had a go in one of these years ago - didn't rate it.
    No, wait... that was a Nissan Primera! :lol:
  3. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Great design but IMO the glossy finish makes it look cheap.
  4. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    Nice review. I like the looks, design and cooling performance of this case. I wonder how easily a fan controller could be fitted?
    Edit: There is a matt black option (with red LED's) and a glossy white option (with blue LEDs). I don't know if either of these versions will be sold in the UK.
  5. Vault-Tec
    30 Aug 2015
    Hory shet the orange peel on that paint !
  6. Dogbert666
    17 Jan 2010
    This is mentioned :) I couldn't find the matt one for sale here though :(
  7. ViperSeven
    ViperSeven What's a Dremel?
    29 Jul 2016
    Release a premium edition, something akin to the Fortress line. Matte black, fan controller, USB C, Lose the super car angles, Leave the front a open as it is (love that), Full panel side window (or as close as you can get it) and a bottom fan filter removable from the front.... That for me would be the perfect case.
  8. t5kcannon
    7 Jan 2011
    Ah yes very true; sorry, I read the first page a bit quick. About a fan controller, how easy would it be to fit one?
  9. Dogbert666
    17 Jan 2010
    I'm not a modder so I can't say for sure. I'll ask Antony what he thinks :)
  10. Combatus
    16 Feb 2009
    Depends which one you're after tbh. I've sat 5.25in bay controllers on flat surfaces using double sided tape or velcro before and made custom mounts using acrylic or metal, but an easier option would be the NZXT Grid+ v2 which can be mounted anywhere.
Tags: Add Tags
