Hardware SilverStone PS06 Review
Discussion in 'Article Discussion' started by arcticstoat, 21 Oct 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Zurechial
    Zurechial Elitist
    21 Mar 2007
    A case review from Harry, good start to the day. :D
    I love the syling of this case, it's a shame about the weak air performance.
    However.. I wonder how it is for a water setup? That's something I'd love to see in bit-tech case reviews, but I understand that it would be incredibly time consuming and difficult to provide watercooling suitability/performance testing for every case review.
    Some at-a-glance information in that regard, or even more photos from different angles would be helpful that way.
    It has always struck me as odd in a way that cases are tested and performance-rated only with their supplied fan configuration; but I can understand why this is the case too.
    (Pun not intended).
    So, in saying that: What's the case like from the perspective of finding places to mount internal rads? Are the drive cages removable? Is the floor of the case suited to a 120.2 radiator with some modding, or are there multiple layers of metal that would make that awkward?
    I've been looking for an attractive replacement for my Stacker 830 for quite a while now, but I'm picky when it comes to styling and this one suits my taste; but I also like to keep my radiators mounted inside the case (120.3 and 120.2, just to be awkward!) so finding the right chassis is tough!
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    I agree with Zurechial, In the old BT days a 'wc' section in the review was mandatory. But i think in 2011 Water-cooling is not interesting anymore since most CPU's are doing great on air-cooling.
    Since BT has a large modding community it should at least use a mockup radioator (2x120 or 2x140) to see if it fits, I think a lot of modders want to know.
  4. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    For me, the space behind the motherboard tray would be absolutely crucial.
    There are only a few things which disappoint me about my armor suit and one of them is the space behind the motherboard tray.
    If you have braided PSU cables and god forbid a captive PSU (like me) then I would like at least an inch.
    If this means the case is bigger and a bit more expensive then so be it.
  5. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Did SilverStone really need to give it such a beating with the ugly stick?
  6. Tangster
    23 May 2009
    The y must have run out of fairy design dust to s sprinkle this one.
  7. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    its cheap and not aesthetically appealing enough for shelf let alone the price
  8. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    So many issues in this one paragraph! Firstly; exhaust INTAKE? Make your mind up, it either exhausts or it intakes it can't be doing both.
    As to the second part of the quote, why is a roof fan blowing air down? Maybe there was a manufacturing mistake. I'm frankly amazed that you'd even consider fitting a HSF to blow down onto the graphics card. I should imagine orienting the HSF upwards and fixing the roof mounted fan to also exhaust air out of the case would improve results.
  9. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Woah, Silverstone, what are you doing?
    Don't go the way of Antec, please.
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    First up thanks for the spot; we do our best, but some times type-o-s slip through.
    Secondly, there's no mistake - the roof fan is definitely an intake fan; it's that way on SilverStone's website, and was this way when we removed the case from the box. I made the point about re-orientating the cooler to counter inevitable "what-ifs" from readers. Obviously it's a stupid setup!
    Regarding re-orientating case fans - that's not representative of the product; the air penetrator is only of use as an intake due to its excellent directed airflow properties; it wouldn't make sense to use it as an exhaust.
    Answering some earlier questions as well; the case will only support 120.1 radiators, in either the rear or floor mounts; the 180mm roof mount is only accessed from the outside of the case, so no room for an interior mount or tubing; its an air-cooling case. if you guys want it, I can start making sure to talk about a case's radiator compatibility in future.
  11. Aragon Speed
    Aragon Speed Busily modding X3: Terran Conflict
    12 Jan 2009
    It would make sense to me. Even if it's only mentioned what, if any, size rads would fit. If Zurechial hadn't asked, some por sap may have gone out and bought the case with a "Yeah, bad air cooling, but I'll stick a couple of rads in it." kind of approach.
    As most people now shop on-line for tech parts, there isn't an opportunity to have a look inside a case for ourselves in a store. You guys have the kit on hand, so it would make sense just to mention if a case could be used for a fluid cooling system or not imo.
  12. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    looks like CoolerMaster Haf/Cm Storm Trooper stuff... and others with this Batman/Terminator Salvation sci-fi type look.. Not a bad job of it imo. I like it when comparing side by side picts I have, it's target market. But if you want to do a sci-fi type look make sure some more sci- goes in to it. Understand everyone here wants to push more ... or they learn to push the systems more with the help of good folks here. I'm one of those aforementioned people wanting to push .. and learning how. SilverStone is on my list of quality products. I've been considering the cases mention above for a Theme project, just a concept atm . SilverStones PS06 fits nicely ... hits the target market... me :)
  13. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Cheers for the answers, Baz. :) I'll have to keep looking for a replacement for my 830..
    I'd definitely appreciate comments on radiator suitability in case reviews, as the stock-air-cooling config is something that doesn't really factor into a purchasing decision for me all that much; whereas it can be difficult to get reliable information on rad mounts in new cases.
    If there's the potential for modding to make room for radiators at a glance, that'd help too!
  14. JCBeastie
    10 Nov 2005
    Weird set-up!
    Sorry to be a pedant. :)
  15. LooseNeutral
    13 May 2010
    Would love too see some picts of the top of case at a few different angles! Cover on and off. I have to say I keep coming back to look at this one. :)
  16. randis1981
    randis1981 What's a Dremel?
    4 Nov 2010
    please revision COOLER MASTER Elite 430
Tags: Add Tags
