Cases Silverstone Raven 2
Discussion in 'Hardware' started by Rocket_Knight64, 30 Jul 2009.
  1. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
    Found by accident that the Raven 2 site is up with more info:
    http://www.silverstonetek.com/raven/products/index.php?model=RV02&area=usa
    I'd have a look at this linked preview while you are at it. It's asian but easy enough to navigate and quite good. They also display some ingenious cable management. Cant make out any temp or noise readings though:
    http://www.chiphell.com/2009/0722/88.html
    Over all I'm thoroughly impressed. Much better then the RV01. But it does seem that you cant install HDD's without first removing the motherboard. :duh:
    From reading the instructions it also seems that it ships with a pair of brackets to attach a 120.3 rad directly on top of the 180mm fans. Be very interesting to see how that performs or is at all practical. :dremel:
    The new Fortress FT02 is also based on the same platform but with a better HDD cage, alu exterior, foam padding, one less PCI slot and fixed speed fans.
    Cant wait to see how these fare compaired to the Obsidian and new Lian-Li's.
  2. droitwichdosser
    droitwichdosser What's a Dremel?
    25 Apr 2009
    now what i need is something like that, but i want the DVD drives to be pointing out the same way as the window.
  3. Krikkit
    21 Jan 2003
    That looks like a pretty good case tbh. The way the HDD's are laid out you won't need to take out the mobo to remove them. Clever use of space for the SSD too.
    Not sure on the silver, but in black that could be a nice case indeed.
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    The original Raven looked way too plasticky (for a Silverstone case anyway), this one looks a lot more workable. It'll be very expensive though, I'm guessing ~$300?
  5. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Anything I say about that case would be obscene. Shouting bird obscene. It is secks.
  6. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
  7. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    If this was a more affordable £100ish then i would probably get one, it looks awesome.
  8. Hoffs
    Hoffs Seek
    25 Apr 2009
    Don't know if I can mention this but another website similar to this said that Silverstone Raven 2 will retail for between £100-£120.. This will definatly interest me in my upcoming build
    It also goes on to say that it will be released mid-August so not long to go
    http://www.hexus.net/content/item.php?item=19419
