Hardware SilverStone Raven RV02 Review
Discussion in 'Article Discussion' started by Lizard, 9 Sep 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. memeroot
    memeroot aged and experianced
    31 Oct 2009
    Testing tougher with less heat being produced in the case and more fans sticking it out?
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Seems like a good improvement over the old Raven.
    Its a shame that the case isn't a bit taller to accomodate GPU's such as the HD5970. If this was the case you could run a HD5870 and a 60mm radiatior without any clearance issues.
  4. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    It's good, but not good enough to pull me away from a 600T.
  5. Combatus
    16 Feb 2009
    Sorry, are you saying our testing is not as tough as it used to be?
  6. Hustler
    Hustler Minimodder
    8 Aug 2005
    I have come to the conclusion that i am mentally unable to process the concept of these 'wrong way round' cases....
    Everything about it just seems...wrong.
    Sigh....getting too old now to embrace new ideas.....
  7. memeroot
    31 Oct 2009
    @Combatus
    I was being a little tongue in cheek - I think testing is as good as it ever was certainly - but the component choice is naturally easier on some cases being less dependant on the heat disapation from the inside of the case.
    I do however think the tests are better and more suited to real world circumstances and are less likely to down grade good cases due to the inability to use an unusual (passive) graphics card.
    one quick question....
    would rotating this case 90 or 180 degreed (with suitable clearance) honestly make any difference to cooling?
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Can anyone tell me - is there an RV03 or FT03 coming soon?
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Hmm, I thought the RV02 and the FT02 were the same, apart from the obvious cosmetic differences, so I was expecting identical cooling performance.
    Can you share your thoughts on what you think the reason is for the difference in cooling performance between the FT02 and the Raven?
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    FT02 uses the air penetrator fans
    the RV02 does not
  11. Combatus
    16 Feb 2009
    Ah ok! I'd probably agree with what you said although the CPUs are actually fairly similar in TDP and the HD 5870 draws nearly twice as much power - obviously it's actively cooled though but still relies on the case providing good airflow.
    Rotating the case, or rather the motherboard tray won't improve cooling on it's own. The CPU cooler might be lower in the case where the air temperature is generally lower but in most cases, it benefits from rear/roof exhaust fans so it would probably be hotter. The Raven RV02 and FT02 both have three 180mm fans in their base though and move air in the same direction as the CPU and graphics card. The only way you could get the same kind of airflow in a standard tower would be to have three 180mm fans in the front of the case - not ideal.
  12. DocWolfe
    DocWolfe What's a Dremel?
    21 Mar 2009
    It's a shame the hard drives aren't more accessible, like in the FT02
  13. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    I actually like it and will consider it for my next build.
    Would you see any problems if you added the new Corsair H70 CPU cooler? (We are due a review of that as well by the way!)
  14. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    isn't there an E version coming out with AP fans and ft02 style hdd cages?
  15. Combatus
    16 Feb 2009
    There is indeed!
  16. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
    Indeed there are! But i would not expect them anytime soon. RV03 get compacted with questionable styling, and the FT03 is M-ATX in the style of the old Apple toaster cube.
    http://www.atomicmpc.com.au/Gallery...rtress-ft03-cases-are-fiendishly-complex.aspx
    I personaly like the FT03. RV03 needs a bit of modding. And then there is the TJ11.. :O
  17. Lockon Stratos
    Lockon Stratos I Will Snipe You!
    19 Apr 2010
    the case looks nice - I understand the general concept - but one thing i dont understand is why the sidepanel is on the RIGHT hand side - my case sits to my right hand side & my side panel is on the left hand side. what RAVEN have smartly done here is created a case of left handed people! DEATH TO RAVEN!!!!! GIVE ME MY RIGHT HANDED CASE!!!!!
  18. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    It makes sense in a way, as you'll see more of the top side of your nice jazzy graphics/sound cards in that orientation.
    I have an Akasa Eclipse 62 (with clear side panel) on my desk to the right of me at the moment, so if I got this case I'd just put it on my left. It may take a bit of getting used to but I do like the look of this case. And yes, my desk really is that big.
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Air cooled this case does well but using their adapters to install a Triple Rad and water cooling, the temps actually become worse... if your doing CPU and GPUs, there isnt enough exhaust and the internal temps and the temps of the Rad just climb. Personal experience... so ya great for an all air cooled rig or a CPU only cooled rig but the moment you throw in a few GPUs into that cooling loop. the temps skyrocket. I ended up giving this case away to a friend simply because I was not happy with it, gorgeous case but ya...
  20. shaffaaf27
    3 Jun 2008
    cheers, any release date?
Tags: Add Tags
