News Silverstone SFF PC fits full size graphics cards
Discussion in 'Article Discussion' started by Sifter3000, 26 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Mraedis
    Mraedis What's a Dremel?
    5 Sep 2009
    I'm curious what people use these cases for?
  3. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Hmmm.... I quite like that.
    I wish X58 based mITX boards were available.
    Probably a relatively high-end gaming rig for LAN parties etc. I love SFF so I'd have one just as my primary gaming rig tbh.
  4. Sifter3000
    11 Jul 2006
    Tiny main PC - I mean, you can get a good GFX card in and a Core i5 750 so you'd be all set, then...
  5. Hg
    Hg The game known as life
    3 Aug 2007
    I just built a gaming pc from the winnings of a bit-tech comp using a SG05 case, Zotac m-ITX 775 board and a GTS 250, watercooled with a H50 great little gaming pc for the girlfriend.
    As such i will be looking at this case in the coming months to replace my machine, making lan events easier, only concern for me atm is there seems to be no where i could fit a water cooling kit like the H50.
  6. Krikkit
    21 Jan 2003
    This looks absolutely brilliant, perfect for those folks that have limited space or don't want a case on the floor.
  7. Guest-23315
    Guest-23315 Guest
  8. Pete J
    Pete J Employed scum
    28 Sep 2009
    Tasty!
    My brother wants a new computer to go with his iMac 27". I might have to base the build around this case...
  9. memeroot
    memeroot aged and experianced
    31 Oct 2009
    tower cooler possible? also interested with corsair...
    to be perfect needs 1x240 location for dual graphics radiator + 1x120 for cpu's
    any chance?
  10. Yoy0YO
    Yoy0YO Lurky Lurker
    20 Mar 2009
    if you look at the top of the 180mm fan, there appears to be 4 holes allocated for the 120mm fans. you'd most likely be able to mount the 120mm rad/fan here. if not, use cable ties to tie the rad to the 180mm fan, kinda ghetto but it'd do the job.
  11. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    Ah this would be awesome for lanning, I wonder if it's possible to get proper watercooling kit inside it...
  12. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    I haven't use a SFF case since the days of my MSI mega 180 which in itself was rather sweet and is now being used by a friend and still going strong. I did find it used to run rather warm and would be interesting to see just how cool and also quiet this case could remain with even a medium range graphics card like a 5770 or 5850 compared to it high end brethren.
    It certainly looks the part and is definitely far better ventilated than my old MSI box. In the article it is said that it can take 2 x 2.5" SSD's which is all well and good if you are looking for a higher end product, but they could just as easily be 2 x 2.5" laptop drives.
  13. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    +1
  14. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
  15. Xir
    Xir Modder
    26 Apr 2006
    ...so do the Shuttle ones, but with dedicated PSU's (and dedicated mainboards.)
    This could be a good alternative though.
    What do you use your's for? Housing a PC?
    You get one DVD-Drive, a harddrive, upto two SSD's, a full Oomph graphicscard, an appearently not too small cooler and a PSU in there, what more do you need?
  16. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    PCdesignlabs' Qmicra did this years ago...
  17. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Wonder what'd be the temps with a GTX480 inside. :X
  18. Floyd
    Floyd Wire Twister
    4 Dec 2008
    I love how the big selling feature on this was fitting a large card and none of the pictures show it with a large GPU.
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I love SFF but after building Project FEAR (Using a TT Lanbox Lite) and dealing with cramped space (didnt help I shoved a full water cooling system inside) I think I will stick with Mid Size or Larger. ^_^
  20. Hazchem
    Hazchem Minimodder
    3 Dec 2004
    This looks amazing, great features too.
Tags: Add Tags
