Hardware Silverstone SG05
Discussion in 'Article Discussion' started by Guest-16, 1 May 2009.
  1. Guest-16
    Guest-16 Guest
  2. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Do that again and it's an insta-ban.
  3. The boy 4rm oz
    10 Apr 2008
    I can see great things for this case. Cut the sides off the removable shell, mount them permanently, mount a few radiators and your laughing lol.
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    ME wants.
    That case looks sweet, now only if I actually had a use for a ITX system. :)
  5. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Lovely case! Me wants too.
    Would gladly have it with the setup from the review instead of my current ATX rig.
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    It looks like a airconditioner.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Agree with oasked 100%.
  8. Htr-Labs
    Htr-Labs What's a Dremel?
    16 Jun 2008
  9. Guest-16
    Guest-16 Guest
    I have seen and requested from Lian Li already at CeBIT - we're still waiting on it, but I'll get onto them again. Maybe I'll just steal one while I'm in Taiwan in a months time... ;)
  10. Htr-Labs
    16 Jun 2008
  11. The boy 4rm oz
    10 Apr 2008
    If that Lian Li was natively horizontally orientated and had a little bit extra pazzaz such as a thin chrome strip running down the front like they do on some of their other cases I would be all over it. Personally I think it is just a little too plain, reminds me a lot of a NAS box lol. I'm not saying that it's ugly, it is actually quite beautiful in its simplicity but personally not to my taste.
  12. interzen
    interzen Real men use chainsaws.
    18 Feb 2009
    Under the appropriate circumstances it would probably sound like one too :)
    Any chance of a better definition of "not too intrusive" when it comes to fan noise? Not necessarily an 'x dbA' type figure but some kind of reference point would be handy - could be looking at the basis of a new, and relatively portable, audio-mangling box :)
  13. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I was checking a modded one of these out at PPCs headquarters last week. Interesting little units. I really thought they'd be aluminum though for some reason. No biggie I suppose. Only gripe I'd have about it is cosmetic; I'd prefer a metal front. ;)
  14. CSMR
    CSMR What's a Dremel?
    22 Oct 2008
    Great case for a quiet machine (using external psu and replacing the 120mm fan).
  15. naokaji
    naokaji whatever
    8 Dec 2006
    Shame Silverstone didn't think about installation a bit more, I know, it's not a case where you are going to mess around inside regularly, but still, it's Silverstone, so I would hav eexpected better.
    Best part about it is that you can fit a normal psu, so you are free to use higher end components or buy a psu thats silent and efficient unlike the crap thats usually included with cases (and with small ones often not replacable due to odd size).
    They should have copied the look of the tyr and call it tyr-100:clap:
    But then it's probably better that they didn't, or I would be building yet another pc:D
  16. Htr-Labs
    16 Jun 2008
  17. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    what cpu cooler were u using
  18. Jozo
    14 Mar 2009
    I think they used ZALMAN CNPS8000. It is designed to be a low-profile heatsink
    Newegg linky or if you prefer manufacturers site
  19. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Not to nit-pick, or anything, but most Shuttles don't support dual-slot cooler video cards. The usual layout has a PCI or PCI-X 1x slot on the inside, and then the video card on the outside.
  20. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I know what I am buying soon :D
    Thanks bit, making me broke, review by review.
    /joke
Tags: Add Tags
