News SilverStone SST-ST360 Power Supply at MODTHEBOX!
Discussion in 'Article Discussion' started by GreatOldOne, 31 Aug 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    MODTHEBOX! has another PSU review for us, this time on the SilverStone SST-ST360:
    "The rear of the PSU, which would normally be seen from the rear of the computer case, is completely stamped with small ventilation holes, presumably to lessen airflow restriction. On the lower left (upper right when mounted) of the rear is the AC inlet plug, which connects the PC to the wall outlet, a simple ON/OFF switch and a 115v/230v slide switch, selectable depending on location and electrical service provided. One item that I noticed was missing was a secondary AC plug. Secondary AC plugs have started to become default options on most high-end PSU units since many consumers use it to power secondary devices such as monitors or water cooling equipment."
    Full review here
Tags: Add Tags
