iv just finish my new rig and have left over cpu i5 750 ram 4GB (2x2GB) Corsair DDR3 PC3-10666 gpu EAH6950/2DI2S/2GD5 psu Corsair Enthusiast TX V2 CMPSU-650TXV2UK 650W cpu cooler corsair hydro series h50 cpu cooler ordered a Asus Maximus III Gene Republic of Gamers P55 Socket 1156 8 Channel Audio mATX Motherboard and want to get the Silverstone Sugo SG03B but not shore if my gpu will fit can any 1 help
According to the Asus website that card is 11" long. According to the Silverstone website the Sugo SG03 can take cards up to 10.5" long. http://www.asus.com/Graphics_Cards/AMD_Series/EAH69502DI2S2GD5/#specifications http://www.silverstonetek.com/product.php?pid=65&area=en
If you don't fit a fan into the lower position in the front you can make the card fit into the case. And I'd cut a hole into the top of the case to fit another 120mm fan with the radiator of the H50 installed in the front. Little bit of modding required to fit everything, but nothing too hard to do.
