Hardware SilverStone Sugo SG08 review
Discussion in 'Article Discussion' started by brumgrunt, 17 Sep 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. guvnar
    guvnar What's a Dremel?
    19 Aug 2010
    Honestly, £169.99 for a mini ITX case - cost should match the size!
  3. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Yes, very pricey. Shame, as I am looking for a mini-itx system for lanning with. Dragging a CM 840 classic about is getting tiresome.
  4. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    The pricing really is quite off. My FT03 is much bigger, also made of aluminium and costed just £110. And the BitFenix Prodigy can also squeeze a watercooling setup in too.
  5. Lance
    Lance Ender of discussions.
    6 May 2010
    Don't forget to take off £53 as it has a powersupply.
    At the moment this still interests me because its still the best looking of the M-ITX systems. I also don't really see the appeal of tool-less entry, especially on a LAN rig, as it just reduces security.
    But cable management! Why didn't they put some cable management in. Tut tut.
  6. Bokonist
    Bokonist What's a Dremel?
    2 Mar 2011
    Nice case, but too much for a mini case, even with the PSU included.
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Still waiting for a release date for the uATX SG-09
  8. Jehla
    Jehla Minimodder
    8 Jan 2010
    10mm front panel? Isn't that a little overkill?
  9. Paradigm Shifter
    10 May 2006
    Agreed. I paid less than that for my Corsair 700D. Hell, I paid less than that for my Silverstone TJ07!
    Possibly even more - some PSUs in that Wattage/Amperage are even more expensive. Doesn't really excuse the price, though. If it was in the ballpark of £100, it'd possibly be worth thinking about. North of £150? That's an instant no. :(
    Because if they'd done that, it would have added another £50 to the asking price, and then no one would buy it. ;)
  10. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Nice, but a more custom PSU wiring set-up is sorely needed, I paid £140 for my Fractal Array and the PSU leads are custom fit to ease air flow.
    Why is a case less important than a CPU or MoBo ?
    IMHO
    dunx
    P.S. Looking forward to a test of the Node 304 ;)
  11. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    I'm having hard time believing you're still complaining about the necessity to wield a screwdriver when putting together a PC. I mean really, aren't you supposed to be tech enthusiast or something?
  12. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    Seriously, I consider such a "feature" as a bonus. I prefer screws and thumbscrews thanks very much.
    I hate plastic rails for drives. Give me four screws and the ability to adjust for fit.
    I hate plastic catches along the PCI slots. They aren't secure (especially for movement) and there are often incompatibility with some cards that means the catch doesn't work.
    And if they aren't made well then they rattle.
    Even if you are swapping components in and out daily or weekly, it is not much more hassle to use a screwdriver.
    It shouldn't come as a coincidence that of my three PCs, two are in Silverstone cases and one is in a Lian Li.
  13. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    For that kind of money, it come have room for (and include) a Fleshlight.
  14. fluxtatic
    25 Aug 2010
    * better have (and that might be the most classic Freudian slip ever.)
  15. abezors
    abezors Lurking since '08
    21 Apr 2010
    I do love my PC. But thats next level enthusiasm for you hardware!
  16. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Couldn't wait for Bit Tech and built in one of these two weeks ago. It's a dream to work in (considering the size), the build is awesome and whilst it's louder than my Fractal R3 (duh!) it's bearable for watching low volume movies at night.
    Also, got a BD burner for £45 which you can't do in full size.
    Expensive? A little bit, sure. But great VALUE and the way forward as far as I'm concerned.
  17. Pot Of Jam
    Pot Of Jam What's a Dremel?
    6 Sep 2010
  18. Siskods9
    Siskods9 What's a Dremel?
    16 Aug 2012
    Seems way to pricey for what you get.
  19. shah
    shah Minimodder
    29 Jan 2010
    Is it possible to use H50 for the CPU?
  20. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    Is it crazy I'm really tempted by this over the much cheaper bitfenix?
    I am trying to hold out for haswell before doing my HTCP but I'm really struggling haha. I keep pricing a build. Its all just sitting there in my basket waiting for me to order.
Tags: Add Tags
