Hardware SilverStone Sugo SG13 Review
Discussion in 'Article Discussion' started by Dogbert666, 12 May 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Xir
    Xir Modder
    26 Apr 2006
    there's a lot of potential for a very compact and powerful system.
    there's a lot of potential for a very loud and dusty system
    Fixed that :D
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Linus Tech Tips went a bit nuts and put a Titan X and an E5-2699V3 (18-core Haswell EX) in one of these. With an AIO cooler, it ran without any temperature issues, though obviously fitting everything in was a bit of a squeeze to assemble.
    This is a REAL SFF case. Not the sort of sillyness (like the Bitfenix Prodigy) that are larger than many mATX cases.
  4. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    @edzieba - entirely agree with you. While there are plenty of small mITX cases along the lines of the SG13 (I have an SG05 on order right now), the Ncase M1 is still remarkable in that it's layout has yet to be duplicated on a reasonable budget by any case manufacturer I know, unless I'm missing something, of course... I would love one of those things, but not at that price. Make a low-cost steel version, I'm in!
  5. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    this vs Corsair 250D?
  6. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    But if I were choosing one I would have to have severe space limitations before I went with the SG13 over the 250D
  7. Redbeaver
    15 Feb 2006
    Ah... it looks similar at a glimpse lol
  8. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Exactly ! I bought a Lian-Li PC-V353 and put it on my Ikea drawer (the same one used for the Ikea DIY render farms), because it was too big to stay on my desk.
    What shocks me is that The Lian-Li is almost the same size than the 250D, while being an mATX case
    • Lian-Li PC-V353: (W) 288mm / (H) 286mm / (D) 397mm
    • Corsair Obsidian 250D: (W) 277mm / (H) 290mm / (D) 351mm
  9. MightyBenihana
    8 Sep 2011
    Did you look at the the V354? I think that is smaller.
  10. jbvertexx
    jbvertexx What's a Dremel?
    9 May 2014
    Terrible review. I have built many systems based on the SG05, and it can house quite a powerful system for probably the smallest Mini-ITX case on the market that can fit a full length graphics card. I've never had any cooling issues.
    This case is clearly intended either to (1) use an AIO liquid cooler or (2) use an SFX PSU which would allow for a slightly larger cooler. Primarily #1.
    I understand the desire to compare cases on equal terms, but this was designed for AIO - you could have at least built it with that config and reported results.
    For the $$, this case almost can't be beat in terms of value and performance in the smallest of mini-ITX cases.
  11. GuilleAcoustic
    26 Nov 2010
    I was considering the V354 when I changed my rig, mostly because the V353 was discontinued. But I found one for very cheap on Amazon (70€) that it was a no brainer. I really like the look of the 353 and it has the exact same footprint as my Ikea drawer.
  12. Cei
    Cei pew pew pew
    22 Mar 2008
    The Thermaltake Core v1 is better than this, despite costing basically exactly the same. It has the PSU at the bottom, complete with dust filter, yet also take a 145mm CPU tower cooler and a full length GPU (seriously, it fits a 7950 with Sapphire's TriX cooler).
  13. Cei
    Cei pew pew pew
    22 Mar 2008
    So, err, you're paying the same price for a fraction of the materials and impaired design? Great.
Tags: Add Tags
