Hardware SilverStone TJ08-E Review
Discussion in 'Article Discussion' started by arcticstoat, 7 Sep 2011.
  1. arcticstoat
    arcticstoat Member
    19 May 2004
  2. longweight
    7 May 2011
    Any idea when this will be available?
  3. Instagib
    Instagib Well-Known Member
    12 Mar 2010
    They've been out awhile. Scan are currently sold out though.
  4. longweight
    7 May 2011
    Any idea where I can get it? Can't seem to find it at the moment.
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    nom nom nom .... interesting
  6. bOO9000
    bOO9000 New Member
    7 Sep 2011
    Can you review the Fractal Define Mini soon please ?
  7. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    I like this case, but the easy access drive bay should have been made central for aesthetic purposes. It makes me twitch having it slightly ajar.
  8. NetSphere
    NetSphere New Member
    15 Jul 2011
    Any idea if we could get Bit-tech to do a review on a mediocre case + Air Penetrator fans and see the difference in cooling?
    Almost get the impression that the Silverstone cases are ok and the Air Penetrator fans make them awesome... As opposed to the cases being great and the AP fans making them even more awesome.
    Imagine a Fractal Design R3 + AP Fans? Has anyone done that?
  9. Xir
    Xir Well-Known Member
    26 Apr 2006
    That's so thraight-through cooled it's almost BTX :D
    With that loadout, you could leave out the harddrive tray entirely (was empty, right?)
    Would the Be Quiet! Dark Rock Advanced have fit where the tranquilo sits now?
  10. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    cooling is brilliant .. it just looks cheap and a bit naff
  11. Farfalho
    Farfalho New Member
    27 Nov 2009
    Great case really. Might consider it for future builds, for a LAN Party PC or to my friends when building a new rig for them
  12. Flip
    Flip New Member
    24 Sep 2009
    Hmm I might be interested in this one, I actually like the look of it.
  13. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    We already have, you can read it here.
  14. abezors
    abezors Lurking since '08
    21 Apr 2010
    If *only* it was ATX and not just mATX! It could have been a real contender against Lian Li A05nb.
    At least the price is spot on.
  15. S1W1
    S1W1 Active Member
    25 Mar 2011
    +1
    I was wondering that as well- it would be great to see a review of the AP fans, including testing them in a range of other cases instead of the stock fans.
    I guess that would be a fairly obscure review though- you guys probably have better things to do with your time...
  16. kzinti1
    kzinti1 New Member
    13 Apr 2010
    Is there some unknown reason that the size of the case cannot be shown in the title of these reviews?
    I really can't see how typing "Full Tower", "Mid-Tower", "Mini-Tower" or whatever other basic spec could not be listed with the name of a reviewed case in the header of its review.
    The only reason I can imagine I really can't bring myself to consider. Editorial laziness just doesn't seem possible since the reviews are so thorough, therefore some other reason of which I am unaware must apply.
    Elucidate, please. This seemed to be a rather interesting case until I finally realized, on the second page, that it's of the mini/micro variety of which I am not the least bit concerned.
    You have wasted my time with this article. Something which cannot be replaced and is the most precious commodity there is. Hopefully I haven't wasted some of it myself by asking that you correctly title your reviews.
  17. longweight
    7 May 2011
    If you had read and fully understood the review then you may have noticed this, the first sentence of the second paragraph on the first page:
    Unlike normal micro-ATX and ATX cases, which mount the motherboard with the CPU area at the top, the TJ08-E places the motherboard upside down.
    This is your first clue to the fact that the article could possibly be reviewing a micro-ATX case.
    It is also stated in the second half of the last sentence of the seventh paragragh
    Meanwhile, a similarly generous CPU cooler clearance of 165mm also means that, despite the TJ08-E’s diminutive size, there are few limitations on your hardware choices beyond the micro-ATX motherboard.
    You seem to have also missed the specification table at the bottom of the first page that states both the case dimensions and the motherboard sizes that it is compatible with.
    I do apologise if you did miss this whilst reading the article. I understand that you are disappointed that Bit Tech have committed a huge journalistic faux pas by not adhering to the International Article Title guidelines and I am sure that they are sincerely sorry for wasting your time by doing so. I am not sure I fully understand these guidelines, elucidate please.
  18. skreenname
    skreenname SFF Forever
    11 Jun 2009
    I think he just wanted a way to tell from a glace what type of case it was.
    So in a list it would be:
    Micro-ATX tower - TJ08-E
    Full tower - Thermaltake armor
    Mid tower- Tuniq 3
    etc.
  19. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    I'm looking to build a new PC in the next month and it has to be a mATX form factor as I need to get the thing on a plane (not looking forward to that tbh) and I want to take it as carry on. This seems quite a decent prospect, but I am now torn between this and the Lian Li V354 (just as I had finally decided - thanks BT). This is cheaper but what about the build quality in general? I was considering using a Corsair H60 with the V354 but I could maybe use the Dark Rock cooler with this, again making the overall build cheaper. Argghhh, why does this happen just when you have decided on a build!!!
    BT has never reviewed the v354 so I am just wondering if anyone here has some experience with it.
  20. fluxtatic
    fluxtatic New Member
    25 Aug 2010
    Dude, chill. The odds I'll ever buy most anything bit reviews are 1M:1, but I don't consider it wasted. A little education does an ignorant body good. You've never watched a cat video on YouTube or sat staring out a window for a minute? With the preciousness of your time, I'm surprised you could elucidate so circumlocutorily on the subject. Time's running out! Get to the point, man!
    That said, this case is relevant to my interests - I'm looking at micro-ATX cases for a project in the very early planning stages, and most of what I've found so far have been ass-ugly.
Tags: Add Tags
