Cases SilverStone TJ08-E
Discussion in 'Hardware' started by User-sam, 20 Oct 2011.
  1. User-sam
    User-sam When in doubt, follow your nose.
    10 Apr 2010
    Hey
    I am looking to buy a new case latter this year for a new computer build of mine, and the case I'm currently looking at is the SilverStone TJ08-E for my new build. I am salvaging my gtx560ti and buying another one for SLI I wanted to know though if this case would support 2 and if there would be any airflow problems. any help greatly appreciated.
  2. longweight
    7 May 2011
    You will get poor airflow due to the small space between PCI-E lanes on a mATX board, the case has great airflow so should run SLI fine.
    Why are you going SLI? What resolution do you game at?
  3. User-sam
    10 Apr 2010
    Ah Right Thanks, and I Game at 1080p at the moment but thinking more for upgrade options down the line, such as I'f I cant run BF3 at max etc.
  4. longweight
    7 May 2011
    You should be fine at that res, if you need more grunt then I would sell your 560ti and get a single get GPU :)
