Case Mod - In Progress Silverstone TJ11 Carbon.....Final pics
Discussion in 'Project Logs' started by kier, 6 Jul 2011.
  1. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    nice one ! subbed!
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    the photos are looking spectacular Richard... :thumb:
  3. kier
    kier -----------------
    1 Mar 2011
    Update: First carbon practice
    3M Di-Noc CARBON FIBER FILM
    Yesterday been playing with the carbon film
    To test my skills, I have coated my classified block with the film
    before
    And after
    Also my Supreme HF coated. Again before
    And now with carbon look
    Put everything on the motherboard
    Also did the laptop
    Just kidding
    The waiting is for the materials now, but luckily I have some stock
    For the radiators I’m gonna make a sort of bracket, from beginning to end of the case, at least on the visible side
    other side gets an open area for cables and other purposes
    Piece of iron plate with the angle to cut
    Round edge marked
    Cutout for the psu
    And here the custom plate, perfect fit
    Opening made for the radiator, so that you don’t see the mounting holes and just straight to the air intake of the sidepanel
    Sidepanel on it
    Rear intake is gonna be closed and the whole will be covered with carbon
    That’s it for today.
    Bye bye
  4. zoom314
    zoom314 Minimodder
    10 Jun 2003
    Nice 2 360 rads, My project if I ever get the case will need 2 psus and 4 rads, But then I crunch numbers for S@H. But then I'm putting together a PC w/6 GTX295 cards...
  5. mnpctech
    21 Apr 2003
    Nice job on the rad install :thumb: and I love the di-noc carbon fiber on the blocks
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This is going to be EPIC!!!!! Awesome looking blocks! Was that difficult my friend?
  7. kier
    1 Mar 2011
    You are crazy my friend..........6x GTX295 :jawdrop:
    Thnx, didt it al for nothing lol, Had a nice deal for other motherboard yesterday.
    the Asus RE3 also with WC block, but i'm gonna do this one also
    Hi AnG3L, Not to difficult later on i'm gonna write a little tutorial
    for the blocks and the panels
  8. LazyMan
    LazyMan What's a Dremel?
    9 May 2010
    If this is anything like your HAF X it will be absolutely amazing. Are you planing on leaving the case exterior black, or having it painted?
    Also, one other question....with the two rads at the bottom, will they be fighting each other for air space. I see you have both rads pulling air in from the outside and exhausting in the case, with them being in such close proximity to one another will this present and problems with the overall cooling and or the longevity of the fans.
  9. kier
    1 Mar 2011
    Yes, there are some things from the HAF-X that I want to do in this one
    The idea is to do the side panels and the front plate with carbon film
    I tought about that and the psu is gonna be placed horizontal, that gives me above the psu a air outlet (hope this is the right word for it) and I'm placing in the midplate two fans with a nice cover, blowing air through the case into the lower compartment.
  10. kier
    1 Mar 2011
    Update: Front plate
    Fortunately i’ve received some products this week, modding time !!!
    To place some hdd’s put the hdd bays together
    To get this build a little over the top I’m gonna put in 3 BP hdd coolers. A while ago I had two from L3p bought for a future build, but this is the perfect case for the coolers. So This week i’ve bought the third. L3p Thanks man!
    Later on hdd's underneath with some support at the sides
    The bay is accessible and gonna be placed like this
    And i’ve used an old piece aluminum panel that I had left after a window cutout ........ never throw something away
    Draw some Lines for the jigsaw
    After some sawing and filing it already starts to take shape
    Adhesive tape over it to see how it is going to be
    And tried without tape
    After that the slot for the slim-line DVD-RW
    And then put the plate on the upper and lower bay cover with
    3M Scotch Clear Mounting Tape #4010
    And put everything back
    But not finished yet ....... missing something.
    I ordered some yellow acrylic. Really a gamble because no pictures were there of the yellow color
    But fortunately it is just the right color that fits with my yellow sleeve
    Made some french fries
    And made the yellow lines in the slots of the hotswaps. Don’t have to be open because the water cooling. And the yellow lines will come back more often in this build
    And the remaining three hotswaps finished
    Imagine the front plate with carbon film (vertical straight lines)
    And finally a hardware exchange. The Classified goes out the to a buddy of mine, he was in love with the carbon blocks. And I got an nice opportunity
    Rampage III Extreme
    With EK full cover block
    This will also be covered with carbon;)
    That's it............Grtzzz
  11. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    That little bit of yellow on the front looks awesome. I think you're a little crazy with your 3 HDD coolers, but they're cool looking. Cool stuff. That's pretty crazy that you got a near perfect color match there, you should go gambling with that kind of luck.
  12. LazyMan
    9 May 2010
    Sounds good....saw your recent post and this is looking EPIC! What material did you use to make the french fries?
  13. kier
    1 Mar 2011
    Thank you, I know the coolers are a bit to much.............but I like it
    Was really happy with the color :clap:
    Thanks, used the acryl in the picture above :thumb:
  14. Combatus
    16 Feb 2009
    Wow, this one's come on a lot since I last saw it! Looks like it's going to be a water-cooled monster :D
  15. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    I really liked the french fries. Nice accents.
  16. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    bloody beautiful.. this is gonna be good!
  17. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    I loved the TJ11 when I first saw it, and I have loved Kier's previous mod. This is gonna be an amazing project.
  18. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Ok, I subbed. Happy now?
  19. kier
    1 Mar 2011
    Thanks, have vacation now so can make a lot of progress these days
    Lol, the idea came from a facebook pic from Mnpctech
    I think so yes
    I must admit, I thought it was a nice case..............now I'm loving it
    So easy to adjust :clap: I think Silverstone has done a great job.
    Finally............Why did it take so long? :D
  20. stonedsurd
    11 Mar 2009
    Subbed! Just stumbled on this and I like the idea :)
