Case Mod - In Progress Silverstone TJ11 Carbon.....Final pics
Discussion in 'Project Logs' started by kier, 6 Jul 2011.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Simply Stunning :rock:
  2. skreenname
    skreenname SFF Forever
    11 Jun 2009
    That tubing is how watercooling should be done.
  3. Scrappy
    Scrappy Mod in progress!
    10 Jul 2011
    This looks extremely nice! Great job! i have been followng this very closely... im glad i did, Well done mate!:thumb:
  4. Tungil90
    Tungil90 What's a Dremel?
    29 Nov 2008
    Wow! Nice Build! :) Look stunning....
  5. kier
    kier -----------------
    1 Mar 2011
    Thnx you guys, and thank you Bit-tech for the motm nominee
  6. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Well desserved:)
  7. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    I gotta tell you. You won me over with that pict of your wiring to the mobo a little bit ago. Now seeing the care you've put into the watercooling connector alignments and tubing.... man 'o man.. this is a beauty all around! Not used to broadcasting my vote but you got it!... heading there now :)
  8. kier
    1 Mar 2011
    Thank you my friend, I think it's not only the outside, but the inside and details needs just as much attention.
    Thank you for the vote
  9. djzic
    djzic Bokehlicious!
    8 Nov 2010
    congrats on motm, got my vote, and by the way you're winning ;)
  10. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Its the straight pipework that makes the difference with the watercooling.
    Another visual feast of a build... You really know how to make a clean system.
    I think we should see some Kier and MnpcTech teamwork in the next mod!
  11. pHuR1u5
    pHuR1u5 What's a Dremel?
    12 Aug 2011
    Mate...
    I have been browsing these forums for a while now, your case has forced me to register just so I can compliment you on what an amazing job you have done. Your attention to detail is phenomenal and the worksmanship is unsurpassed.
    You have gotten me thinking on what case I should try to mod! (probably destroy!)
    Keep up the brilliant work.
  12. kier
    1 Mar 2011
    Thank you very much, just start modding my friend
    Start small, measure twice before cutting and read as much as you can.
    And I know you will succeed
  13. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Colours are right, neat and very clean. Awesome mod this.
  14. capman
    capman What's a Dremel?
    16 Sep 2009
    Looks great your rig
    Out of curiosity would a pair of 420 radiators instead of the 360s have enough room in that case with a PSU at the end?
    As a 360 and 280 are comparable in respect to surface, would a pair of 280s give you even more room at the end? It seems to me that the grills in the case sides are 14cm in width. And you only need 4 instead of 6 fans.
    Why are you not pulling in the air on one side of the case and blowing it out on the other?
    Regards
    capman
  15. kier
    1 Mar 2011
    Thnx, and yes it's possible to put two 420 rads and a psu
    Only 2 x 280 rads? but there,s a lot of space left then, to much I think
    I dont want the "hot" air coming out the first rad into the second one
  16. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I've said it before, and I'll say it again. I'm not really a fan of the carbon look.
    But this is just hands down epic! Which is also why I voted for you in MOTM. :thumb:
    And how you find time to just spit these amazing mods out all the time! Damn! :)
  17. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Looks good !but i dont think the hddcooling is necessary at all :/
  18. kier
    1 Mar 2011
    Yeh I know ;) but it looks great
  19. ciberjack
    ciberjack What's a Dremel?
    12 Aug 2011
    the owesomest MOD! really its great!
    i have some questions. [​IMG] how u can eject the DVD's???
    you have explained how to make the aluminium pannels but u havent told the measures of it... :(
    @kier
    im buyng this case and i want to make the same mod (with some differences) if i want maked the pannels from you, un can do this? how many it cost me? thx :)
  20. kier
    1 Mar 2011
    Update
    Great news......did almost all the sleeving, a hell of a job. Only a few more sata and usb
    And I was busy with the loop in the lower section. used the Y fitting for draining and to the rad
    Almost finished with the BP links
    Maybe you've noticed but almost all the red on the motherboard is gone......pci-e, red button and the red sata. Did this with black film
    Next step is to make a slot in the tray for some cables like the power led, switch, usb and other stuff
    So time for Dremel action
    And finished
    Placed the hardware back
    Not finished yet, I mis the yellow line
    So I've cut a piece of the yellow acryl
    Again used some black film
    Paste it and cut out the lines
    And placed it on the tray
    Still waiting for the last fittings, hopefully next week and then.....................fill up the TJ ;)
    Grtz.
