Hardware SilverStone TJ11 Preview
Discussion in 'Article Discussion' started by CardJoe, 22 Nov 2010.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Right side panel ruins it.
  2. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    I kind of like the case styling but I'm not 100% sure about it, something just seems a little bit off, you know? The feature list would be enough for me to put up with it but the price is a deal breaker :jawdrop:
  3. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
    Hmmm a good case with some excellent features, not sure about the mainboard tray allignment or those fans inside.
    Dont think it will replace the TJ07 as the WC daddy either, because there's no real advantage over it, a 120x4 will fit in a TJ07 with out a problem too and is a lot cheaper, wont be changing mine for one anyway.
    Good but not good enough.
  4. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Can't wait to see some nice UV / LED liquid cooled systems in this new case. I love my TJ07B. :)
    That is pretty: [​IMG]
    I make use of all my 7 bays in my TJ07B. If you are watercooling you need to move the hard drives from the bottom chamber to fit a radiator down there so 5 of my hard drives take up 4 bottom bays (4 drives in a SilverStone fan bay converter in pic below and 1 using antivibration mount in it's own bay above), then above those are Scythe LCD fan controller, then bay reservoir, and finally DVDR in the top slot.
  5. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Yep... I find it quite beautiful, but at $700 I'll get a TJ07 and be well on my way to getting the rest of my WCing gear with the money saved...
    Still; If I ever come into a large chunk of cash... There will be one of these sitting pretty in my office.
  6. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Yes it does, otherwise it looks good, but not as good as the TJ07 which is just a tragedy to be honest!
    It really is amazing that none of the manufacturers have taken a note from the design book of Mick64's mockup over at Xtremesystems. Dual radiator zones, multiple HDD bay mounting options, PSU mounting options, IO input, pwr & rst button mounting options, reservioir mounting options...the list goes on!
    Mick has simply taken all of the input from anyone with something constructive to add and created something which can almost undeniably be called the ultimate case.
    Hope he wins the case design competition!
  7. stn
    stn What's a Dremel?
    13 Nov 2010
    Looks very good! Only expensive!
  8. t1alek
    t1alek Mind modder.
    24 Sep 2009
    The styling is not too bad, just get rid of the window, but.. it's not at all a case of my taste. I am more of a FT-03 kinda guy.
    Guest-16 likes this.
  9. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    Was thinking I had a candidate for my next build (at the rate of a build every 3 or 4 years). I have been looking out for one ever since I put this together.
    Shame the price is so ridiculous. For that amount I could buy a top end motherboard, CPU and RAM when Sandy Bridge hits. It's a stupid amount to spend on a case, premium OEM or not.
  10. Earthmonger
    Earthmonger Gnarled Old Tree
    21 Aug 2009
    To be honest, I never liked the TJ07. Not surprising then that I find the TJ11 just as horrid to look at. The Fortress 02 on the other hand, I did like. $700? So what. Costs the same as a top of the line GPU, but will long outlive it. Where's the issue? $700 is getting close to custom money though, and Silverstone's stamped-out special just can't compete with a custom case.
    My issue is only that it's ugly. I respect Silverstone for staying true with aluminum designs over cheap-arsed steel and plastic though. (Ya'll can keep your crappy 800Ds.) Just wish their current lineup weren't so 'off' aesthetically.
  11. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    I would like to see one in the flesh first,
    however from pics, even though i believe its ally, it looks so tacky and plasticky looking.
    front is ugly and boring as hell, price too high, but understandable as alot of work prob has gone into this, even if it was wasted time.
    Last pc i did in the tj09 as i didnt like the tj07, but this one is a miss for me (although i dont need a case).
  12. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    Yes it's all black, yes it's enormous - but it's too chaotic and messy.
    I think it should be more subtle and also what about the coloured and messy cables inside?
    For that price tag I would expect them to be braided or black at least (hints as Corsair's Obsidian)
  13. KidMod-Southpaw
    28 Sep 2010
    Way too many drive bays, they really could have better use or at least make some room. Who has nine DVD drives? I do hope this will be in Scan's 2010 dream PC.
  14. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    1st and 2nd part of the article: <3
    3rd part of the article < / 3
    :waah:
  15. Guest-56605
    Guest-56605 Guest
    Thanks but no thanks
    I'll stick with the TJ07... :thumb:
    Simple as that
  16. Phoenixlight
    Phoenixlight What's a Dremel?
    29 Oct 2010
  17. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    huh I like it, wouldnt pay that much for it.
  18. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
  19. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    I disliked the TJ07's design, but this I love.
    I'd even spend all the money on an insane SR-2 rig just for this.
    :D
  20. Guest-16
    Guest-16 Guest
    It won't handle an SR-2, only XL-ATX. I thought it did but it was a misunderstanding at what Silverstone said, so I removed it from the text :)
Tags: Add Tags
