Hardware Silverstone Treasure TS01B 2.5" Enclosure
Discussion in 'Article Discussion' started by Tim S, 27 Apr 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    I think it was Baldur's Gate II
    When reviewing Joe, remember to go for the eyes!!
  3. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    If it was stolen, Can the thief not just take out the disk and put it in another enclosure?
  4. Guest-23315
    Guest-23315 Guest
    Nice, but I got my aluminium one for £2 off Amazon, so I don't see how this is £20 better than that.
  5. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    i think it would have something to do with the actual drive, since it has to be formatted first but thats just a guess
  6. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    "arrrrr!!!! wers me Treasure ?"
  7. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Well recognised - Minsc's response when approached by Devin.
  8. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Does it feature encryption, unlocked by the RFID key fob, or does it just "unlock" the disk ? (Which *could* be bypassed I think by mounting the drive in another machine and fiddling with it, I think)
    Without encryption the system might be useless.
    Does anyone know where I could find some Y usb cable like the one on the pic ? (1x miniB, 2x usb male : 1 for power and 1 for signal and power ) as I have a WD passport, which comes with a straight USB to mini B cable, and is sufficient to power it from my PC, but my brother's laptop can't power it, so I need such cable.
  9. zero0ne
    zero0ne Minimodder
    19 Jul 2004
    what g3n3tix said,
    I mean you talked about the RFID crap, but you never mentioned EXACLTY how the RFID makes it "secure"
    if the data on it is not encrypted, whats the point?
  10. TheEclypse
    TheEclypse What's a Dremel?
    11 Aug 2003
    I imagine the RFID tag gives the encryption key. Thats why it needs a blank drive to start with, because it assumes all data on the drive is encrypted. If it cant distinguish between which files are encrypted, then all must be otherwise everything you had on there to start with will be turned into rubbish by the decryption.
  11. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    So, when connecting something like this to a pc, you have to have both the USB connection and the USB power connection? Right? Or can it just pull the power off of the existing mini USB port?
    I have a WD passport that just needs one cord, and I love that fact.....
  12. CardJoe
    3 Apr 2007
    IIRC both cables are needed
  13. Pricester
    Pricester What's a Dremel?
    25 Aug 2002
    Does the RFID tag have to remain in place the whole time you're using the drive, or just to connect? Given the usual state of my desk, I can see some non-comic moments when shifting things around, knocking the key fob off the exact spot and finding the file copy that had been going on for the last 20 minutes mysteriously aborted...
  14. Jipa
    5 Feb 2004
    I happened to review the same enclosure recently and it also works with just one USB-cable connected to the PC. Outlawaol: It's the same 2,5" HDDs inside all of these drives so how do you think some drives would require more power? :)
    And also; I tried removing the HDD from the enclosure after the encryption process and swapped it back to a normal casing. Windows didn't find any partitions on it, so I'd say it's encrypted instead of just being "locked". And I also think it's a good thing the drive shows as empty as the thief/the one who finds the lost drive will most likely just considers it new and empty because of that.
    You have to just show it to the drive once and it keeps going until you disconnect it.
  15. completemadness
    completemadness What's a Dremel?
    11 May 2007
    I'm sorry, but this review seems a little - well half ass-ed
    You say its secure because it has RFID - how is it secure? did you even test its secure?
    When the encryption is a selling point of this drive (its why your paying the money) - would it not be worth testing this?
    How easy is it to bypass the RFID protection? is the encryption actually secure, or just to stop casual's?
    2.5" drives don't have a particular power limit
    they are 5v, however they can vary in the Wattage/Amperage they need - i guess this is what would kill it
    I also got a WD passport, mainly due to the fact it runs purely off USB which makes life ALOT easier (especially with like laptops)
  16. Jipa
    5 Feb 2004
    Please go ahead and tell me how to fake an RFID-tag. I'll be happy to test as soon as you come up with something :) I also have no idea how to test how "secure" an encryption of some HDD is, go ahead and tell some software for testing this as well.
    2,5" drives don't have a specified maximal power requirement, but I'd assume they all take pretty much the same current in the 5 V line. (i.e. if one 5400 RPM 2,5" drive works from a single USB-cable then so do most of the others. It depends more on the USB host than the drive...)
  17. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    Anyone knows where to find a Y usb cable ? I've failed in my search.
    My Passport only needs 1 plug, but I might need 2 on another PC because it won't start up.
    As for encryption : I read an article about a similar hdd w/ rfid, and the guy tested the "encryption" (it was just a xor, claiming AES !)
    http://www.heise-online.co.uk/security/Enclosed-but-not-encrypted--/features/110136/0
    So much for security.
    IT APPLIES TO THIS DISK !! (read end of article)
  18. DannyDirect
    DannyDirect What's a Dremel?
    23 Apr 2008
    someone steals it, pop off the end, end of story lol, however, who is going to steal your hard drive, the only modern day thief's are called Chavs and im not sure they even know what a hard drive is lol, have a nice day.
  19. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    Its been a month and bit-tech has not answered any questions above relating to the review which is a shame as im interested in this enclosure too.
  20. mikeuk2004
    3 Sep 2004
    I bought one of these yesterday from Scan which arrived today.
    However im very disapointed because I for the love of god can not get this darn thing to work.
    My hard disk works fine, I plugged it up to my desktop and formated it as NTFS and installed it into the silverstone case and then nothing. None of my 2 laptops will detect a disk and neither does my desktop. I removed it and plugged it back into my desktop and removed the partition all together and tried again. Still nothing so I formated it fat32 and again no detection.
    Is this a case of dud equipment or am i doing somehting wrong ??????
    All I get is a blue light when I plug it in. For information im using a 40GB Segate 2.5 SATA hard disk.
    So far ive wasted 2 and a half hours tring to get an enclsoure to work:wallbash:
Tags: Add Tags
