News SilverStone unveils upcoming cases and PSUs
Discussion in 'Article Discussion' started by bit-tech, 5 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I don't need it...
    BUT I NEED IT
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Oh, you definitely need it.
  4. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    That glass vertical mobo case makes me happy, I can't afford it but oh well.
    Can somebody explain the trend for fans running sideways through the front of the case. Is the idea to provide radiators with airflow that doesn't vent into the main chamber? Does it actually do anything beyond looking like a dog's dinner?
  5. fix-the-spade
    4 Jul 2011
    That one makes more sense then, but it's still a design choice I'm seeing in lot's of other (not Silverstone) cases where it seems to be nonsense to me.
  6. edzieba
    14 Jan 2009
    Potentially you could fit a wider radiator than your actual case width, but I'm not sure if any designs actually take advantage of that.
  7. suenstar
    suenstar Collector of Things
    13 Sep 2009
    I really want the Alta S1, but at the same time I don't because it'll mean I have to completely re-arrange my office space... plus I keep meaning to downsize and that definitely isn't a downsize.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    Would be hard to take advantage of since radiator manufacturers are all about length and thickness, but not width.
  9. edzieba
    14 Jan 2009
    120x3 and 140x2 are pretty close in terms of actual fin area, but the 140x2 will be shorter and use quieter fans. It will however be wider, so would need an overall wider case if mounted in the normal orientation. Even moreso with 180mm rads.
Tags: Add Tags
