ok heres a quick question... My case has a little indentation in the front where a case badge would go.... but i don't want a case badge because i am going to paint a larger picture over that area. My problem is: How do i fill that indentation so that the front of the case is just flat (ie with no indentation)??? I went to an arts store and the dude told me to just fill it in with glue, but i've already made a cdrom button extension out of a matchstick and i don't want to go TOO ghetto... What i am asking is: a) what should i use to fill this thing? b) how should i do it? thx Chuckles
assuming its a plastic bezel, the easiest way would to use plastic body filler (Bondo) basically it is a 2 part system, that you mix, fill in the hole and sand smooth with its dry. its pretty easy to work with and a great solution if your gonna paint over it.
Could use Milliput Its a 2 part epoxy putty, any good model shop will sell u sum or something similar. Just fill, sand then paint.......job done
Make sure that whatever you use, you sand the whole area you fill to be flush with the surrounding "natural" (heh) plastic. Good luck! Gordon
