Simple, Clean, Effective, Practical Case (No Rice)
Discussion in 'Project Logs' started by sik wit it, 14 Oct 2004.
  1. sik wit it
    sik wit it What's a Dremel?
    1 Jul 2004
    started as a gateway case that looked like this (not my pic, pulled from google)
    and this is the final result...
    *Notice below how the 2 front 80mm fans move air unobstructed onto each side oh the hdds, giving amazing cooling to the hdds and perfect flow to the inside of the case and out the 120mm exhaust
    *And these pics below are of the switches for the fans
    The major mods I did to it were....
    1. add 4 Vantec stealth fans...3x80mm, 1x120mm (stock case had no fans)
    2. dremeled holes in front and side panel for 80mm fans
    3. Constructed custom plexi HDD rack for maximum cooling
    4. wired switches for fans and mounted in front of case
    5. customed stealth power switch and mounted in front of case
    6. cut hole in top part of inside panel for wire management
    7. sleeved every PSU cable
    So, back to the case, it is designed for maximum air flow and a clean, simple, not-riced out look (for those of us who appreciate it)
    PS: I'm still waiting on a 4x20 char LCD I'm supposed to recieve that I will place over the two open 3.5" external drive bays
  2. sik wit it
    1 Jul 2004
    ok well iupload is bein gay right now, so Im gonna need to find a new image host...bare with me people
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    looks good so far but it needs a bezel...
  4. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    photobucket.com
  5. sik wit it
    1 Jul 2004
    username and password for photobucket?
  6. apHytHiaTe
    apHytHiaTe What's a Dremel?
    9 Jul 2004
    you sign up for it..
  7. sik wit it
    1 Jul 2004
    ? most forums have a moderator sign up and then the username and pw is posted in a sticky..:wtf:
  8. Langer
    Langer Jesse Lang
    24 Jan 2004
    www.photobucket.com is in no way afiliated w/ bit-tech.
    all you need to do is sign up for a free account. (also I'd suggest that you tone down on the sass)
  9. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    or alternatively use www.imageshack.us .. free, no registering..
    u can use the thumbnail coding so big logs are more 56k friendly... and still ocntain plenty of pics
    hmm, 120mm fans rather than 80mm 'loud as hell tornados' wud have been better.. either that or for same noise.. the 120mm delta Focussed Flow fan.. 190cfm's
  10. Crim
    Crim What's a Dremel?
    1 Jan 2003
    You see? it's calling from the original place. It's easy to get around these prophibited linking, you just add a ? to the end of the url. I'm sure other things work but thats what I use.
  11. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    fix yer pics up!!! ive got 2 of these sitting in my garage atm and im keen to see what your doing!!!
  12. kenco_uk
    28 Nov 2003
    Get nekkid? What, now?
    Pics still no worky if you've tried sorting them, dude.
  13. sik wit it
    1 Jul 2004
    THREAD FIXT
    thanks for BEARING with me
  14. Nexxo
    23 Oct 2001
    Strangely enough, I like. Simple. Clean. Functional. Elegant.
  15. sik wit it
    1 Jul 2004
    thanks
    I feel a little better now after causing that whole image hosting melee :p
  16. sKuLLs
    sKuLLs What's a Dremel?
    20 Feb 2004
    I agree with nexxo, it looks nice, just all the wholes scream make me look pretty :rock:
