Windows Simple Excel 2010 question
Discussion in 'Tech Support' started by rainbowbridge, 10 Mar 2012.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    OK simple question for any excel pros :)
    ...dirrectory tree report created,
    - want to be able to sort the output so the longest is top or the bottom and it deprecitates going to the shortest.
    Also, I would like to be able to create a new cell on the right and get the count of chracters used for the file path,
    So like this..
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    If no one else sorts this for you, I'll do it in about 3 hours.
    But it'll be a VBA script.
  3. rainbowbridge
    26 Apr 2009
    go for it, ill send £6.50 via paypal if you get me a fix for this.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Add this formula to the 'Total Chars' column and sort on that.
    Code:
    =len(A1)
    =len(A2)
    =len(A3)
    edit: It'd be easiest to have the path in column A then the formula in column B (no blank columns)
  5. rainbowbridge
    26 Apr 2009
  6. rainbowbridge
    26 Apr 2009
    ok cool now how can I apply that to all feilds in G going down wards?
    Edit, ok cool copy A1, all the way down and it updates it.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Formula dragging is great eh :)
  8. longweight
    7 May 2011
    This is a really good little tip!
  9. rainbowbridge
    26 Apr 2009
    pm me your email for pal £
    also for ref why I am doing this, ntfs has a file limitation of 255 chracters, Through bad data management basicly some dirrectorys have exceeded the 255 limit, I need to work on this and a report to see whats going would be helpfull, the data is just standard business reports, pdfs, excels, research...
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Interesting as I had the same issue at work earlier this year. Migrating to a new file server/SAN, although we have software to rename directories pre and post copy as there's over 4TB of office files it'd take forever doing that manually!
    You can put a conditional formatting to highlight the over length paths.
    http://www.howtoexcelatexcel.com/excel-tips-tricks/conditional-formatting/
