Guide Simple Lighted Fan Mod
Discussion in 'Modding' started by Gryph, 30 Sep 2003.
  1. [Jonny]
    [Jonny] What's a Dremel?
    1 Sep 2003
    You could do this with UV Fans? And stick some UV LED's in them, that would look kinda sweet. :)
  2. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    UV LED fans would be sweeeet !!! :clap:
    I'm doing a black and red theme on my current case (mainly cos I got a surplus of 5mm red LEDs at the moment), but I'll DEFINATELY keep that UV idea in mind for the next one :thumb:
  3. Gryph
    Gryph What's a Dremel?
    10 May 2002
    If your leds are getting burnt out, then parhaps they are a lower voltage breed than the blue ones I used.
    If you dont want to use resisters to lower the voltage to safe levels, you will have to put more of them round the fan.
    12 / <number of leds> must be equal or lower to the leds rated forward voltage.
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    oh, it works AMAZINGLY with UV fans. I did this to one of my 80s. As to bulbs burning out, it's due to too much voltage. In fact, since i ran the three on my UV fan at 4v (max!) for a while, two burnt out. Now, if you have 4 running in series off of the 12v line, you get an even, resistorless 3v each.
  5. Dazbo666
    16 Dec 2002
    Just had a thought, and remembered that I've got a crystal 120mm fan and a UV reactive 80-120mm adaptor waiting to be put over my CPU once I get my new case....
    ....so maybe I can put some UV LEDs into the adaptor, and get a backlighting effect on the 120mm fan?? :naughty:
  6. sk8ero
    sk8ero What's a Dremel?
    27 Oct 2003
    this is exactly wat i been looking for for my PSU
    i have a Topower Phantom that has a clear fan in the front and in the rear
    but the fan in the rear is a slim 80mm, so i cudnt replace it with an LED fan, but now i can just add LED's of my own
    thnx
  7. Nieko
    Nieko What's a Dremel?
    21 Apr 2004
    Hello from the NooB.
    This is a great little tutorial. I have some Noiseblocker fans that are beggin' for some LED lovin'. Sould look great with the blue blades. :)
  8. DeAtH07
    DeAtH07 Banned
    29 Mar 2004
    dam that fan looks so nice! Were did u get it? :rock: :thumb:
  9. Nieko
    21 Apr 2004
    Noiseblocker fans can be had at Whispertec.com.
    Sorry, there are no US dealers yet.
  10. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Dont use bulbs for this mod, only leds.
    If you meant a led, did u use an transistor, or did you connect it directly to 5 or 12 volt? :worried:
  11. toss
    toss What's a Dremel?
    6 Jun 2004
    very clever i like it :) might give it a try
