Linux Simple webserver distro
Discussion in 'Software' started by ZeroX, 27 Feb 2008.
  1. ZeroX
    ZeroX What's a Dremel?
    17 Sep 2003
    I'm looking for a webserver distro much like trixbox and ipcop but I want a clean and small webserver with basic functions like php, mysql, ftp, mail and a webbased configuration! more function is not nessarary, i DON*T want it to be like clarkconnect or ebox with firewall functions!
    thank for your help!
  2. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    debian minimal
  3. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Debian + Webmin then install the other packages you need.
    Sure its a little more complex to setup and its hardly an out of the box solution, but it is highly customisable (mine sits on a 1GB CF card in my NAS)
  4. ZeroX
    17 Sep 2003
    i realy don't want to have a regular linux distro to set up myself, first of all I don't have the time to research what needs to go in, i just want it to work, webmin I have tried and I don't like it at all...hard to find what i was looking for, if i remember correctly.
    i got a tip for this distro on another forum http://www.eisfair.org/en/home/news/ thsi is the best one so far, hopefully i will get a few other tips...
  5. Woodstock
    10 Sep 2006
    just keep in mind that a regular distro will give you alot more flexability, if you ever should need it
  6. ZeroX
    17 Sep 2003
    i'm well aware of that, althou if I need it later i will install it then.
  7. godmonkey
    godmonkey What's a Dremel?
    14 Jan 2007
    Ubuntu 7.10 Server during the install it has the option to do a LAMP install. After that just apt-get ipcop.
    I have only played with it a little myself so I have no idea as to the size though. I went the Debian minimal install and just added what I wanted after that.
  8. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    If you want it to just work out of the box then you may well be better off with Ubuntu. Yes, it has a ton of bloat you don't need, but it has what you do and and it works. It's easier to get rid of stuff than to go hunting for it if that's what's most important.
