Windows sims 2 problems
Discussion in 'Gaming' started by henson0115, 7 Oct 2004.
  1. henson0115
    henson0115 Banned
    16 Apr 2004
    everytime i stat the sims 2 its comes up with an eroor the program carsehed program will now terminate were am i going wrong?
  2. henson0115
    henson0115 Banned
    16 Apr 2004
    anyone??
  3. ou7blaze
    ou7blaze sensational.
    5 May 2003
    http://forums.bit-tech.net/showthread.php?t=71249
    I suggest you do the same as me, reinstall OS, I know it's lame I didn't even do that my comp refused to load windows, it kept passing the POST but not the load of the OS, how lame.
    Now I'm using my spare HD with the old files from like last year, it's laggy as hell and probably has loads of spyware yet Sims2 works -_-
    Funny things computers are...
  4. henson0115
    henson0115 Banned
    16 Apr 2004
    i really cannot be botherthed to reinstall os if this is the last option i will but its annyonig thanks anyway
  5. ou7blaze
    5 May 2003
    Yeah well considering my computer was blazing fast with everything tweaked up and all just that ****ing sims2 won't work, really annoying actually...
  6. henson0115
    henson0115 Banned
    16 Apr 2004
    can i have to xps setups on the same machine like on 2 diff harddrives?? if so ill setup xp on me 40 gb and if so how will i no wich one to boot thanks
