I want to play it now im getting my pc really soon this week but will i be able to play it on my pc and then play it on new one using same code i will not be using same hd since one in this pc is 340g and new one is 1tb. Also can my specs on current pc run it intel penitum 3.0ghz gefore 7300 1 g of ram (and im no vista ) Im not sure since sims 3 box says i need 1.5g or ram for vista but this is windows 7 so im guessing same.
But can i unistall in this pc and then use same key and put it on new pc? and i also played sims 2 with this rig now with gefore 7300 and i found it fine.
My sister plays this on a 1.67GHz sempron with a x1300 Pro at lowest settings around 1024x768/1280x800, runs quite well considering I'm underspec'ed which has never stopped me, can play FEAR2 and Fallout 3 on this machine I'd say if you haven't already bought it borrow someones copy and give it a try.
OMFG im asking can i install it on this pc and then when i get new pc with my new hard drive will i have to buy it again or should i be able to use same cd code to play or is it like i think you can only use it one time?
wow, spaz out much. Ever think that maybe he was answering the first question because he didn't see that you had posted again in the thread? You didn't need to jump down his throat. If you like, I can get a glass of milk, knock that over, and you can cry about it too.
If you uninstall it while having internet access your 'install credits' are returned. IF EA still uses the ****ing system, that is. Most games have official patches that remove that shtick. That is, let's say you can install 1 game on 5 machines, when you install on one you use 1 credit, and you have 4 installs left. Uninstall the one, and you can install it on another while keeping the installs left number constant.
Unless TC decides to go on an installing frenzy, I doubt he'll even have to redeem those said credits, assuming they exist.
