Single button fan/lights controller with LCD Mod (Finished)
Discussion in 'Project Logs' started by SteveyG, 13 Apr 2004.
  1. fillip
    fillip What's a Dremel?
    9 May 2002
    Yes you can name names so to speak. Best places for LED's that i know of are LSDiodes, U.S. compnay but really cheap and only couple quid for shipping too. Or if u want a big batch of a single colour check out Ebay - there are usually job lots of about 100 - 1000 leds there.
  2. smurkey
    smurkey What's a Dremel?
    5 May 2004
    Cheers, I've found a page full of them but it's a bit disconcerting when tehy all use the same pictures for the white leds they're trying to flog. Click here
    Are the one's in Stevey's case 3 or 5 mm?
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
  4. bmph8ter
    bmph8ter What's a Dremel?
    12 Jun 2002
    All I can really say is "wow". Great work.
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    Any rough idea of price?
  6. lv_dicedealer
    lv_dicedealer What's a Dremel?
    2 Sep 2003
    This is an awsome implementation of something that I have been thinking about for a while now. Well done!
    When you add temp sensors to the mix, will you be having parameters available for the duty cycle of the fans based on temp (ie, 50% if temp < 40C and 100% if temp > 50C with some linear proportion in between)?
    Suggestions:
    Set up a lock setting for the controller and use the knob as a Master Lock type thing to unlock the controller. This would keep prying kids fingers out of the mix.
    Also, when the unit is not receiving input from the rotary encoder, have it display temp and fan info like 'TEMP1 42c FAN1 65%' since the rpm readouts from PWM (it is PWM, right?) controllers is kinda wacky.
    I will be keeping an eye on this one as I really like this design. The idea of buying a custom made controller is very appealing :clap:
  7. emuexplosion
    emuexplosion What's a Dremel?
    18 Jun 2003
    Wow. That is impressive, I wish my knowledge of all that stuff was better so I'd understand you when reading that lingo.
    I am about to start another mod for myself, using almost what you are doing, black case, tons of white LEDs. I dislike CRTs because they are much like flood lamps, and I like the "spottyness" of LEDs, looks cleaner.
    What I am wondering is.. is there a way like to create a button or a set of buttons that will control my LEDs in the case, much like a sprinkler system. I would like for there to be "zones".. like front panel, feet, under cariage lighting, flood case lights, drive lights, molex lights, blow hole lights.. etc, etc. Is there a way that I can have a button or something that can dim each "zone" without effecting the others or have some of them pulse or turn off or cycle on and off.. I think that would look very cool.
    Anywho, VERY nice project, I like it very much.
  8. computer
    computer What's a Dremel?
    10 Jan 2004
    isnt that what this mod is about? he has individual control over about 5 lighting zones I thought but you could probably easily expand it... depends if stevey is releasing the info...
  9. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    STEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEVE!
    I don't know how I missed this thread... looks farkin awesome mate, beautiful work with the white lighting. I now see how serious you were when you said LEDs all 'round!
    Fan dabby dosy fan controller too.
    Now get back to revising! :thumb:
  10. SteveyG
    23 Nov 2002
    Thanks all,
    Yes, this is something I plan to have as an option on one of the menus.
    It shouldn't matter if someone turns all the speeds down to minimum, as I've set a minimum of 45% on the CPU and GFX fans, so they shouldn't be able to overheat.
    I also plan on doing something like this, where it will scroll through several screens showing system information. I will be modding some of the fans so that I can get an RPM readout even though it's driven from a PWM controller.
    This is basically what I have done here. It should be possible to increase the number of zones to over 20 without any problems.
    :thumb: Cheers Timtim.
    Actually I was revising, just having a bit of a break...
    Enjoy your revision - especially the analogue electronics stuff :blah:
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Me too, make it so...
  12. ciipher
    ciipher What's a Dremel?
    27 Mar 2002
    Thats a real nice looking project mate congrats!
    Of course I think we'd all love to see the circuit / PIC code! :thumb:
  13. bigal
    bigal Fetch n Execute
    8 Oct 2004
    Just wondering if anything is going to happen over this? :sigh:
    Sorry to bug but i really love this design...
  14. bigal
    8 Oct 2004
    ^Bump^ :D
  15. Zheele
    Zheele What's a Dremel?
    17 Feb 2004
    This is exactly what I want for my control panel. :) (Even though I didn't know it before I saw this post)
    Any chance of a PCB/PIC guide or something like that?
  16. Cybertronic
    Cybertronic What's a Dremel?
    25 Feb 2004
    That's very nice! :)
    I also love the colour theme too :eek:
    I could be interested in one of these if they go in production! :dremel:
  17. computer
    10 Jan 2004
    yeah! we demand the stuff! the stuff the stuff! :p ;)
  18. SteveyG
    23 Nov 2002
    Hi guys, sorry I don't often check the Project Logs section.
    I'm currently in the process of trying to find all my files/find which ones are missing on my pc as windows decided to corrupt the data past 132GB on my HDD after I restarted :sigh:. If I don't have the PCB design on my pc anymore and I cannot recover the files then I'll redesign the PCB over the christmas holidays. I'm a bit too busy at the moment to spend time on this :sigh: Sorry guys.
    There's a few improvements I need to make to the software, so as soon as I do these I'll make programmed PICs available to you all :)
  19. computer
    10 Jan 2004
    coolies... will we be able to get some sort of source code access so we can add our own zones etc and/or if you sell preprogrammed ones?
  20. bigal
    8 Oct 2004
    WOO HOO! I was actually thinking about this only today... :rock:
    Nice one man!
