Single button fan/lights controller with LCD Mod (Finished)
Discussion in 'Project Logs' started by SteveyG, 13 Apr 2004.
  1. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Real sweet man, awesome!
  2. fillip
    fillip What's a Dremel?
    9 May 2002
    I still wanna build something like this for my next project so i'm gonna pick up a PIC starter kit after chrimbo and start playing with some fans, led's and a rotary encoder and see where i get.
  3. JohnFish
    JohnFish What's a Dremel?
    12 Oct 2003
    any news on the schematics/code? Sorry to post in such an old thread but its really interesting and its too bad it got lost in that way. thx
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    With all the work, exams, coursework etc, I've had no time to do anything to do with this project since the last photo I took. I planned to create schematics and update the whole project over christmas, but I had no free time... :sigh:
    Sorry if you guys are getting impatient etc, but I don't get time to do anything but the most important stuff these days. :sigh:
    There's a couple of modifications I need to make to the watercooling, so hopefully when I get time to do that, I'll be able to get everything else done and update the software. Once that's done I can give the code/schematics out to all you guys too.
  5. phoeneous
    phoeneous What's a Dremel?
    16 Aug 2004
    The white is totally Pimpin!!! I like it alot, good job! :rock:
  6. bigal
    bigal Fetch n Execute
    8 Oct 2004
    why thank you SteveyG. Would be Sweet! :D
  7. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    are there any mod guides on how to light up the eject buttons? i can find any here.
    do you wire an LED to an external powersource or wire it direct into the CD drive?
  8. Cybertronic
    Cybertronic What's a Dremel?
    25 Feb 2004
    On page 2, why are the front fan led's only lighting up 2? I thought all 4 dim at once? :worried:
  9. Langer
    Langer Jesse Lang
    24 Jan 2004
    there is a good one in Bit-tech's "mod guides" section, :search: . Or try; www.zapwizard.com.
    Essentially all you have to do is wire and LED/resistor to the +5v line and Ground coming in from your molex.
  10. SteveyG
    23 Nov 2002
    As far as I can see, there are no guides for illuminating the cd drive buttons. Langer seems to be referring to the backlit slot loading drives which isn't what you're asking.
    It's a pretty simple mod to perform:
    Just take off the cd drive bezel and the button should be attached to the bezel with simple compression fittings. Just pull off the button and cut a piece of acrylic to the exact shape of the old button. Attach the button and put an LED behind it ;) In this case, the LED is connected to the controller, so the button dims with all the LED's on the front panel.
    There are only 2 LED's lit up on the fans, because there's only 2 LED's on the front two fans. It wasn't worth modding 4 LED's into each of the fans as I knew they'd only be in there for a month or so, before I installed the watercooling.
  11. AngelOfRage
    8 Dec 2004
    cool, ill give that a shot on an old CD drive before i risk my to DVD drives! thanks
  12. bigal
    8 Oct 2004
    any news on this Stevey? Still prefer the design of this to the 4 output, 4 input USB thing that has appeared lately....
  13. SteveyG
    23 Nov 2002
    Exams are over in a week, will do it then...
  14. bigal
    8 Oct 2004
    nice... good luck in them! :D
  15. mottl3y
    mottl3y What's a Dremel?
    1 Nov 2004
    youre a champ steve, have been hanging out for this since the thread started :D
  16. pcjabber
    pcjabber What's a Dremel?
    24 May 2003
    Stevey, any chance you'll tell us how much you paid for the parts? Also, any possibility you could post a parts list (at least of the major stuff) so I can see how much Digi-Key, Jameco, and Allied Electronics (AKA RS Components -- the two are both owned by Electrocomponents, Inc.) charges for the various items?
    Thanks!
  17. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    nice work on this one. if u decide to build a couple of those controllers i want one for shure. good luck with your exams. keep on modding :dremel:
  18. SteveyG
    23 Nov 2002
    The parts list is pretty tiny:
    2 x ULN2003
    2 x PIC16F870
    1 x 100nF Capacitor
    2 x 4MHz Crystals
    4 x 22nF Capacitor
    1 x Rotary Encoder
    1 x 2x16 LCD
    +Resistors for the LEDs
    +LEDs
    The new version I'll be working on next week will be a bit different though, and there won't be two separate boards. Should have some better functions too :) So don't go buying the parts just yet. >>>>>LINK <<<<<
    I'll be posting in the Electronics forum about the new fan controller and circuits etc. so any questions ask in there.
    Thanks. The exam on SMPSUs was a nightmare today :wallbash: 1 exam left :)
  19. lucasvo
    lucasvo What's a Dremel?
    8 Sep 2004
    Which button do you use ?
    Cool idea
    I'm looking for a impuls-button, which act like this:
    If I turn it makes imuplses for every 20° and if I push it it makes an impuls on an other channel.
    My english is quite poor so it is hard to explain this for me, hope you anderstand it.
  20. bigal
    8 Oct 2004
    a Rotory Encoder is used. This is similar to your description.
